G35 & G37, Coupes & Sedans
2005 G35 Gauges Not Working
Old Jan 1, 2018 | 08:46 PM
Gauvs79's Avatar
I have a 2005 G35. Recently my temp gauge, gas gauge are dead. My speedometer goes in circles, and my odometer will read properly, and then show a 1 or zero. Sometimes the temp gauge and gas gauge will flip all the way around and be stuck on the outside of the gauge range. Should the whole dash be replaced?
Old Jan 1, 2018 | 09:21 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I would check the combination meter chassis ground first but it sounds like you have a complete failure of the meter which means sourcing another one or having someone rebuild it.
Definitely check the ground circuit though, I've never heard of a complete failure like you described, hopefully during the removal you find some glaringly obvious problem.
Does the stereo and AC controls function normally or are their any other electrical issues with the vehicle?
Old Jan 2, 2018 | 01:41 PM
Gauvs79's Avatar
Sometimes the light for the clock and AC display does flash. Other than that, it is basically only the dash gauges.
Old Jan 2, 2018 | 01:43 PM
cleric670's Avatar
BANNED!!!
Ok might be a simple electrical gremlin then. Check out the factory service manual under the section PG (power and grounding).
http://www.nicoclub.com/archives/inf...e-manuals.html
stormtrooper5
Apr 21, 2013 02:46 AM
mellinox
Aug 8, 2010 06:16 PM
BadBoy06
Forced Induction
26
Nov 4, 2008 09:58 PM
InjectedPerformance
Accessories-Vendor
Nov 26, 2007 12:42 PM
damen
Forced Induction
Feb 1, 2005 01:37 PM
