G35 & G37, Coupes & Sedans
Anyone know the difference in CIA g35 to 350z
Old Feb 23, 2018 | 07:54 PM
Melo5812's Avatar
Anyone know the difference in CAi g35 to 350z
i know the motors are the same and I know the cold air intake will fit my g but does anyone know if there is specific differences between them I don't really want one but I need a new boot for the maf so a way cheaper alternative is either a short ram intake or CIA and for $18 more can get a CIA for a 350z worst case I can make it a short ram by not installing the bottom tube but curious if they mount in different places or the filters are in diff places I prefer you know for sure rather than guess ...looked and all I could find was a comparison on the ram air
Old Feb 23, 2018 | 07:59 PM
FreshLikeAG's Avatar
I can tell you the difference between the C.I.A. and a CAI...
Old Feb 23, 2018 | 08:08 PM
You're going to get different opinions on this topic. I haven't seen anything proven that a cai gave them better results on the g35. I think most believe the stock intake is pretty well designed. The 350z's tube is a better design. A lot of people switch out the g tube for the z tube.
Old Feb 23, 2018 | 08:30 PM
Melo5812's Avatar
did u read my post Im not buying it cuz I want to or think it will do anything great I have to buy it or spend a few hundred on the air duct boot that connects to the mass air flow center and damn auto correct lol
Old Feb 23, 2018 | 08:49 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You don't need to spend a few hundred, an OEM G tube can be found for about $25, a Z tube for about $60 but you also need the Z pcv hose so it's a couple more bucks.
A short ram is easy though, 3" coupling and a filter and you're set, and you'll lose horsepower due to sucking hot engine compartment air which truly impresses the ladies (or dudes).
Check eBay for current market prices, if you decide to go the Z tube route I highly recommend the Z pcv tube from Z1 Motordports.
Old Feb 23, 2018 | 08:55 PM
Melo5812's Avatar
i bought a cheap cai from Amazon same one they sell on eBay I'm going to use it as a short ram air if it doesn't fit as a cold air but I can't see why it won't I'll make a bracket if I have to the cold air was 15$ more than the short ram so I said why not I spent $55 total btw found the misfire
nightrider
Intake & Exhaust
May 24, 2006 02:38 PM
anish3232
Jun 17, 2005 11:54 AM
LetsGoo
Intake & Exhaust
Aug 1, 2003 10:07 AM
