2008 Infiniti G35 sedan Stalling when warm low speed no error
Hi All
looking for help.
2008 Infiniti G35 stalling when engine reaches operating temperature or when it’s warm at low speed or uturn and starts right after it.
After start there is no check engine light either.
Its getting often now.
I have cleaned throttle body and maf sensors and did relearn correctly.
I have changed pcv valve on passenger side.
I changed crank shaft sensor too.
Rpm on idle is 600 which I think is low.
Any one can help me and tell me what the problem can be ?
looking for help.
http://x.infinitihelp.com/forum/loca...p=12&keyid=290
You likely need an updated ECM flash from dealer
