G35 & G37, Coupes & Sedans
Rev up to non rev up HELP!!
Old Jan 24, 2019 | 10:54 PM
Ving3's Avatar
Swapped with a non rev up
Hey so I have a 2005 g35 whitch was a rev up I swapped it with non rev up from my old 2004 350z alone with the ecu I'm still using the g35 REV UP harness I got my key programed and started right up and got it tuned .. problem.. I have check engine light on for my cam sensors that are not plugged in due to it's not a rev up and my idle is high . So my question is what needs to be done to get my car running 100% PLEASE HELPP
Old Jan 25, 2019 | 11:35 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Problem found
Old Apr 5, 2019 | 01:44 PM
Pdxnando's Avatar
did you figure out the problem?
Old Apr 12, 2019 | 10:17 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
You might ask a Uprev tuner if those codes can be turned off since they have the pro version, I know just Uprev tuner won't do it. maybe a non revup harness and ECU is an option. or using nisflash and reflashing your computer to a non revup ecu.
G35-31
35
Aug 18, 2016 08:59 PM
Kim Bop
Mar 16, 2011 12:08 PM
brotherhef
Forced Induction
22
Nov 18, 2008 08:10 AM
Exodus
May 8, 2007 09:21 PM
Diamond G35
Jan 24, 2007 06:58 PM
