G35 & G37, Coupes & Sedans
Issue. PO1273 bank one circuit lean
Old Jun 12, 2021 | 10:09 PM
Double007's Avatar
G35 base
2005 g35 Infiniti
I have tried everything 4 oxygen sensors in bank 1 . Pcm replaced used, one pcm repairs made to I chip. Idle relearn. New throttle body, new map sensor, new fuel injectors. New cats. New exhaust manifold gaskets. Pressure regulators It leads me to think there’s a short in the oxygen connector itself? Has anyone has this issue before?it only on the passenger side
Last edited by Double007; Jun 12, 2021 at 10:16 PM. Reason: Did not add year make and model
Old Jun 13, 2021 | 01:47 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Have you tried replacing the spark plugs, I know it sounds odd but they have a dramatic effect on cylinder burn conditions and I've seen lean codes from a fouled set of plugs.
If a new set of plugs doesn't fix it smoke test the intake and exhaust for leaks, either can cause that code but I have a suspicion the plugs will fix it.
vq.4kk
Apr 12, 2021 03:52 PM
Juuly43
Mar 20, 2021 02:56 PM
prnc35s
Feb 26, 2010 03:40 AM
