G35 & G37, Coupes & Sedans
Building my vq35de rev up for 800HP!!?!
Old Aug 3, 2023 | 12:02 AM
Mg35gt's Avatar
2006 G35 6MT Premium w/ leather seats
Hey guys have always been planning on building my motor and turboing it. That being said a recent scenario has come in which has given me a reason to do this sooner (possibly destroyed motor). So that being said I’m hard headed on staying on the vq35de revup platform as I want to keep the original type of motor in the car which is very important to me. My goal is 600-800hp which is a ways a way but I have specked out parts that will be essential to me reaching my goal. I would like your opinion and advice for this new step in my journey and the parts that I have selected.
  • Wiseco Custom Pistons w/ s710 wrist pins
  • JWT C9 Billet Camshaft
  • ACL Race Bearings
  • Brian Cower rods
  • Fluidampr Crank Shaft Damper
  • ARP l19 Studs 8740
  • Boundary VQDE Oil Pump Gears
  • Dynosty Pro Seal 350z Head Gasket
  • Dynosty Billet Girdle
  • NWP 75mm throttle Body
  • Cosworth Dual Plenum Intake
  • CJM S1 Fuel System
  • Injector Dynamics ID 1300cc injectors
  • 2x Walbro 450lph pump
  • Aeroflow 325lph
  • Radium Fuel Surge Tank 450LPH
  • AEM Filter
  • Z1 Coil packs
  • Greddy twin Turbo kit or Boosted Preformance single kit
  • Pathfinder Cooling
  • CZP Aluminum Valve covers
  • Z1 Poly Motor mounts
  • Oil catch can
  • Z1 Diff Cover
  • Z1 Diff Brace
  • Nismo diff bushing
  • Nismo solid subframe bushings
  • Driveshaft shop Aluminum Drive Shaft
  • OS Giken R Tripple Plate Clutch
  • Nismo Sway bar kit
  • Nismo end links
  • Nismo rear camber arms
  • Nismo front upper control arms
  • Nismo rear mid links
  • Nismo rear toe arms
  • Nismo Rear traction arms
  • Nismo Tie rod end links
Old Aug 7, 2023 | 08:29 PM
Urbanengineer's Avatar
Sounds like you’ve got a great list there! Do you plan to daily the car? That’s a ton of whp for a daily. I wish you the best. Every thing I see is what I would order if I was going for the moon too.
Old Aug 7, 2023 | 08:33 PM
Mg35gt's Avatar
I will not be dailying the car 😂, but I do want it to be as reliable as possible for a weekend warrior. Thank you for wishing me the best! This will take me a while but I will keep y’all updated.
NismoSkylineV35
Nov 5, 2020 04:40 PM
GT-Ron
Dec 13, 2005 01:00 PM
