G35 & G37, Coupes & Sedans
what kind of oil to get?
Old Oct 19, 2005 | 04:36 PM
player's Avatar
hi,
im going for an oil change tomorrow and wondering what kind of oil i should go with, i forgot where but i heard after 10k miles start getting synthetic but not sure if thats right..
im at about 9500 miles now and just though i would get some advice from the experts
thanks
Old Oct 19, 2005 | 04:43 PM
hayaku's Avatar
I'm no expert, but lots of people here run Mobil 1 synthetic. I personally use AMSOil full synthethic 5W30. www.g-owners.com has oil analysis reports from G35 users and most run Mobil 1.
Old Oct 19, 2005 | 04:52 PM
mario24601's Avatar
I use Castrol GTX 5W30 with K&N filters.
Maybe later once I have more milage I will go to synthetic.
Old Oct 19, 2005 | 04:56 PM
G35BASTARD's Avatar
castrol syntec 0w-30 motor oil, if it's porsche approved, it's good enough for your G35.
Old Oct 19, 2005 | 04:59 PM
IS300TOG35's Avatar
► Matt ◄
i run mobil 1 extended performance 5w30 (would never run it for the guarenteed 15,000 miles tho) with k&n filter.
Old Oct 19, 2005 | 05:00 PM
bythabay's Avatar
Originally Posted by player
hi,
thanks
whatever you do, go with a Xw40 weight oil.. the high revving vq35 motor wears much better with a heavier weight oil as suggested by oil analysis. In my friends' coupes and my sedan I use the amsoil HDD 5w30 which is very close to a 5w40 weight oil (it actually turns into a 5w40 weight oil after a few K...). I would be interested to try the amsoil 5w40 european car forumla oil as well...
Currently in my sedan I am running mobil 1 0w40
Old Oct 19, 2005 | 06:48 PM
s14roller's Avatar
Unless the car is being operated in extreme conditions or is FI, I'd recommend going with the factory 5W-30. I personally have used Mobile 1 in all my cars.
Old Oct 19, 2005 | 07:09 PM
Msedanman's Avatar
O.F. Administrator
I use Castrol Syntec 5W30 with OEM filters.
I will consider using Mobil 1 also once I use up my Castrol supply.
I use synthetic from the first o/change.
C.
Old Oct 19, 2005 | 07:14 PM
bythabay's Avatar
From the factory our cars are filled with Xw40 weight oil. Manual says either Xw30 or Xw40 weight oil can be used. The Xw30 weight oils are better for fuel economy (slightly), while the Xw40 weight oils are better for protection from wear.
Old Oct 19, 2005 | 07:15 PM
bythabay's Avatar
From the factory our cars are filled with Xw40 weight oil. Manual says either Xw30 or Xw40 weight oil can be used. The Xw30 weight oils are better for fuel economy (slightly), while the Xw40 weight oils are better for protection from wear (given higher rpms or engine load).
Also, I think you would notice a lot less consumption using a 40 weight oil.
Old Oct 20, 2005 | 02:05 AM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
hi,
thanks
MOTUL 300V Case Closed........
Old Oct 20, 2005 | 12:45 PM
ARH_twilightblue's Avatar
I agree with bythebay, go with Mobil1 0w40 or Castrol Syntec 0w30 (the made in Germany one). The Castrol is in the upper 30wt range so it is ideal for our engines. 5w30 is not recommended for the VQ35 anywhere outside the US, and I would especially not run M1 5w30 as that turns into a 20wt fairly quickly... Unless you are willing to trade some wear for tiny bit of gas mileage.
Old Oct 21, 2005 | 12:58 PM
some.devil's Avatar
mobil 1 synth here
philbegas
Jul 8, 2016 07:04 PM
stratous01
Oct 7, 2015 10:19 AM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
CV35Driver
Sep 15, 2015 05:09 PM
UT G35
Sep 3, 2015 03:58 PM
