G35 & G37, Coupes & Sedans
motor oil at express oil service
Old Feb 2, 2006 | 07:49 AM
g35rcr's Avatar
walmart has mobil 1 oil changes for 32 bucks
Old Feb 2, 2006 | 08:17 AM
CMT1111's Avatar
Why not just change it every 3500 miles with dino oil? My dealer has a 2006 special, oil & filter etc $20.06. Is mobil 1 that much better or is it just so you can go longer between oil changes?
Thanks
Old Feb 2, 2006 | 01:25 PM
JerryD's Avatar
Cleaner engine, valves, spark plugs, better fuel economy, less frequent oil changes and many more benefits. I had 2 cars driven over 200,000 on Mobil 1 and no maintenance except spark plugs and timing belt. And still giving 28mph on highway (one 3.8l and 3.5l engines). Bodies fell apart, but engine running well. I know - if you lease for 2-3 years - who cares?
Old Feb 2, 2006 | 02:14 PM
erikill's Avatar
I personally prefer syntec, and its cheaper just to buy the 12 quart cases if you can get them on sale.
Its so much easier to just do it yourself since you know that the oil will be correct, the filter properly tightened w/ a crush washer, no spill on the engine, etc etc. It takes 30mins - 45mins to do an oil change leisurely, just go buy the metal ramps at auto-zone and you are set.
my .02
Old Feb 2, 2006 | 08:44 PM
cungkpham's Avatar
or if you get my employee discount, mobil 1 synthetic oil case for about 30 bucks, or cheaper i think
Old Feb 4, 2006 | 08:40 AM
G35MC's Avatar
jiffy lube uses Pennzoil
I asked for mobil 1, and they said they don't carry them... so I got Pennzoil synthetic oil and Pennzoil oil filter. cost me $60 including tax.
is that bad? the mechanic told me Pennzoil synthetic oil rate better than mobil 1 synthetic oil
Old Feb 8, 2006 | 12:19 AM
L454's Avatar
Be skeptical of any info you get from a Jiffy Lube "mechanic". Most of the guys who work at these quick lube places lack the background to make those kind of blanket statements. The main advantage to Pennzoil Platinum is its lower production costs compared to Mobil 1 a PAO synthetic. Both of those oils will probably perform well, which is better is a little more complicated. Every type of oil has its advantages and disadvantges depending on application. Also any good standard dino oil will be fine for oil change intervals of 3000 miles/3 months.
P.S. From what I understand Pennzoil oil filters are just rebaged Fram filters.
Heres a good link on baragin oil change places if you are interested: http://autorepair.about.com/cs/gener.../aa040701a.htm
Old Feb 8, 2006 | 11:10 AM
gto2050's Avatar
Interesting thread..... I agree with the Jiffy-Lube assessment. Not the sharpest knives in the drawer. I have done all mine at the dealer and interestingly enough, they don't recommend synthetic for the VQ35 engine. No explanation but they don't carry it or recommend it.
I believe you could get reasonable service at any of the quickie lube places if you stood over them. I doubt they would put all the bolts back in the engine bottom aero cover. Every car I have ever taken to them (My 96 Exploder with 132,000 miles) always drips like crazy when I bring it home. They don't clean up anything. My car has never dripped after a visit to Infiniti. Some dealers are better than others. Some are terrible. Mine is pretty good (Ramsey Infiniti - Ramsey NJ)
As for filters, they are all basically rebadged from one company or another. Fram, Hastings, Purolator etc.
Old Feb 8, 2006 | 07:31 PM
MechEE's Avatar
Damn, I get raped for $50 for a dino juice oil change at my local Infiniti dealer.
Gookiecrunch
Aug 19, 2015 12:00 PM
Datsunguy
Aug 19, 2015 01:02 AM
mjfenix
Jul 17, 2015 02:07 PM
