The proper way to heel-toe in a G/Z (video)
OK...
Just to visually express how to proper perform a heel-toe in the G/Z...
Video script
First lift off throttle
Hard on the brakes
Clutch in
Roll your ankle
Blip the throttle with your heel
Shift into gear
Clutch out
www.driftinvasion.com/videos/howtoheeltoe.MOV
File size - 6 megabytes in quick time movie format
Side note: I am asian so i dont wear american sized shoes such as 14EEE and I wore socks so the process can be clearly captured on video.
Video script
Hard on the brakes
Clutch in
Roll your ankle
Shift into gear
Clutch out
well if ur on a track ur supposed to pedal the brake to the metal (HARD on the brakes before u enter the corner)
for street use u can modulate...
i find no problems...
just have to practice and learn the rpm ranges
Originally Posted by mc2
pedal to the medal will usually end up in locking the tires though.
Originally Posted by MechEE
I find it MUCH easier to just roll the right side of your foot on to the gas and keep the left side on the brake. Only works if you have well endowed feet, though.
