I hate aluminum pedals!
Old Jun 2, 2005 | 11:42 AM
wakelawyer's Avatar
Ok, you've gotten me hooked and I've started off with some smaller additions to my car, still a way to go before I'll catch up with others but working on it. Installed the clear corners and Nismo radiator and oil cap, all simple changes. Waiting on the battery cover for the right side which I hope will go as smoothly.
However, I'm ready to toss my pedals. I was out there for about 45 minutes and made no progress. Any suggestions? I think that a heat gun or something similar will be necessary to put on the brake and clutch pedal but also having issues with dead pedal and removing gas pedal.
Unfortunately can't make it to Saturday's BBQ but looking forward to seeing the pictures online.
Russ
Old Jun 2, 2005 | 11:45 AM
Speedoholic's Avatar
G (enie) FUNK ERA
Very simple: fill up a bucket with hot water and throw in the pedals for 15 minutes to get them soften - should make the job easier.
The dead pedal comes out by giving the plastic screws a turn or two and then pulling it upwards (almost prying it out of place).
Hope this helps.
Good luck.
Old Jun 2, 2005 | 11:50 AM
wakelawyer's Avatar
Thanks. I'll try the hot water and see how it works. I am also recovering from a minor surgery so thought the percosets may have something to do with the problems. Not complaining, it makes failing a lot more fun!
Old Jun 2, 2005 | 11:59 AM
infiniti4life's Avatar
i added a little bit of dish detergent to the hot water ti help it slide a little better... it is a PITA to do though
Old Jun 2, 2005 | 05:29 PM
G35PhatS4's Avatar
G SQUAD
For the gas pedal, there's a clip that latches... just pop it, and the thing will slide right now. If ya need help, bring it out to the June 4th meet and I'm sure someone will help ya out... I did Paul's in 5min. =)
Old Jun 2, 2005 | 06:38 PM
Diesel1's Avatar
Moderator
In addition to the hot water, I used 2 flatheads (small handles) and worked the lip around the pedal. PITA, but u'll get it!
Old Jun 2, 2005 | 07:41 PM
lowrider's Avatar
Just to show you guys - You do have a choice. There are other pedals out there. These are perfect for heel and toeing.
Lou
Old Jun 2, 2005 | 09:20 PM
Diesel1's Avatar
Moderator
I saw those on another post you did and wanted to ask ya where you found those. They look nice!
Old Jun 2, 2005 | 10:03 PM
wakelawyer's Avatar
Unfortunately won't be there June 4th but hope to have them on for the next meet after that. Thanks again for all your help.
Old Jun 2, 2005 | 10:48 PM
lowrider's Avatar
Thanks!
http://autovation.net
Lou
alessandro
Oct 8, 2015 09:29 AM
AL8782
Oct 3, 2015 10:26 AM
blnewt
Sep 25, 2015 01:48 PM
