FS:1986 Buick T-Type(not Grand National)
Old Oct 3, 2006 | 10:15 PM
rlwjr1's Avatar
For the uninitiated this car has the same exact drivetrain as the Grand National. The ONLY difference is the GN came in black only, the T-Types came in colors.
Previous Owner Modifications and Repairs :
1) Stock 109 block rebuilt by Ruggles. JE forged pistons, Reed 210/205* 0.470/0.459 110* lobe center. NEW HV front cover and oil pump,not a booster plate.
2) Heads ported fully with Manley stainless valves, stock size.
3) Intake has been ported
4) 42.5/009 injectors.
5) Kirban adjustable F.P. regulator
6) Precision Turbo PT51 with H.D. adjustable actuator, min. psi is 17lbs.
7) Terry Houston downpipe with integral wastegate. Dynomax stainless muffler with 3 inch dump in front of the axle.
8) Repainte the car. Maaco paint job,looks good from 20ft.
9) Recovered the seats front and rear, grey cloth buckets.
10) Replaced the upper door panels. Lower plastic panels are original and in decent shape. A few nicks and scratches here and there. The plastic is not faded and chalky.
What I have done :
1) New Interstate battery.
2) Kirban seat braces
3)Turbo Tweak 93 octane chip
4) RJC Power Plate
5) Century Transmission/Mike Kurtz 200R4 street version. Extra clutches,bigger band,hardened input shaft. Restalled D5 converter,2800 rpm.
6) 4 Bilstein shocks
7) New Moog tie rods, centerlink, idler arm.
8) www.scandc.com stage 2 upper control arm and ball joint package.
9) Global West Del-A-Lum lower control arm bushings
10) 36mm front sway bar. ATR rear bar.
11) Moog 5658 front springs
12) New to the car from GBODYPARTS.COM gas tank. My old one sprung a leak.
13) New Walbro 340 pump,hot wired.
14) New belt
15) Recored 4 row radiator.RMI 25 with just a touch of antifreeze for color and cold weather protection.
16) B&M external transmission cooler. Stacked plate style 11,000GVWR run in series with the factory cooler.
17) New rear brakes,hardware,stock size Buick wheel cylinders,axle bearings and seals
$7900.00 . I will entertain offers.
Old Oct 5, 2006 | 09:31 PM
rlwjr1's Avatar
Old Oct 5, 2006 | 09:35 PM
kraqcommando's Avatar
you will get a better response with a clean up and steam clean
Old Oct 13, 2006 | 12:16 AM
Closer_2001's Avatar
T
Just sent you a PM
