FS IL: 03 g35 coupe..6spd..brembo..bose
Old Sep 25, 2009 | 12:34 AM
IDriveALex's Avatar
Up for sale is a 2003 g35 black with tan interior. Fully loaded with everything minus the navi. Bose sound, 6spd transmission, brembo brakes..etc. I purchased the car used with a bad engine. I found a donor car from arizona and have swapped in a '05 engine with 65k on it. The body itself has 131k of highway driving..front bumper shows chips and drivers seat shows wear. While swapping in a new engine I installed an act streetlite flywheel and an act heavy duty street disk as well as some polyurethane engine mounts. The only other non stock item on this car that I replaced is that I installed a set of hawk hps pads all around. Clear title..never been in an accident asking $12,000 obo. Located in the nw burbs of chicago. Call mike if interested 773-931-3718
Two issues with the car that I know of. It needs tires all around and the radio and a/c have an issue which is common and you would either need a new circuit board or go aftermarket double din.
Old Sep 28, 2009 | 09:24 AM
IDriveALex's Avatar
Here is the vin if anyone wants to check it
JNKCV54E33M218558
Old Sep 28, 2009 | 09:57 AM
Deezflip's Avatar
Originally Posted by IDriveALex
...and have swapped in a '05 engine with 65k on it.
Just curious....does this mean it has the 6MT rev-up engine in it? ECU was swapped as well?
Old Sep 29, 2009 | 09:18 PM
KT-Lex's Avatar
+1 on rev up motor? interested also...
Old Sep 29, 2009 | 09:31 PM
SxSkyLinexS's Avatar
if it is rev-up engine, its a good price!
Old Sep 30, 2009 | 10:54 AM
IDriveALex's Avatar
The engine came out of an a/t sedan. The stock 03 ecu is being used, but you guys got me thinking so im gonna get the vin off this motor and double check it to make sure. It was purchased from a local shop that had a parts car for a good price. Everything bolted up and plugged right in to my original harness. No check engine lights and no problems.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
