FS: TWIN TURBO 04 INFINITI G35 // CLEAN TITLE // 400whp // AUTO
Old Aug 7, 2014 | 06:20 PM
kday's Avatar
Arrow
Selling my 2004 Infiniti G35 Twin Turbo automatic. The car holds a CLEAN and clear title and has 56k meticulously maintained miles. It will come with all invoices, documents and receipts. The car was built by GT Motorsports while only using high quality parts. The car has always been properly maintained and EVERYTHING functions on the car as it did the day it was purchased from the dealership.
The car is turn key and the Engine runs in absolutely perfect condition. The A/C blows ice cold and the heater is warm, even warmer when the seat heaters are applied.
All the work done to the car was done professionally and not a dollar was spared in the build. It is a complete sleeper that you would never see coming but bare in mind that there was over $10,000 worth of labor put into the car. This is an Amazing deal on an even more incredible car.
Please cross reference all pricing..
The Run Down
R2 Custom Car Audio System
Eclipse AVN7000 - In Dash / Navigation / Bluetooth receiver ($2000)
Eclipse CH5061 in-dash 6-disc cd changer
Dual 12" Eclipse 88120ti Subwoofers in custom encloser
2 Surefire 1000w Class D Amplifiers
2 Eclipse EA3422 Amplifiers
FOCAL UTOPIA 165W-rc Components, Tweeters, Crossovers with adjustable levels
(DUAL) Stinger SPV20 High Capacity Batteries
4 Lightning Audio 1.0 Farad Capacitors
Viper Alarm with Remote Start
Dynamat Sound Insulation applied throughout the entire car
Custom Suede enclosure
Custom Suede headliner and sun visors
Custom Fiberglass and painted center consoles
Under the Hood
APS Twin Ball Bearing Turbo Kit
GTM Updated Valvebody for Automatic transmission
Twin Garrett ball bearing turbos
APS 3.5" Intercooler
APS Upgraded injectors w/ walbro 255lph fuel pump
APS High Capacity engine oil pan
Blitz SBC ID Spec R Boost Controller
HKS F-CON vpro with controller Tuned to 400whp
-hks vpc map sensor (4299-RA008)
-hks vpc map sensor harness (4299-RA010)
-hks vpc mixture controller (4299-RA015)
-hks vpc Air Temperature Sensor (4603-RA001)
-hks vpc IAT sensor harness (4599-RA018)
-hks vpc Air temp sensor mount (91112-083100)
-hks vpc Knock Amp (44006-AK001) $760
-hks vpc Knock Amp O2 Sensor (22693-0M500) $590
-hks fcon vpro wire harness (42002-AN005) $550
GTM Updated Valve Body
Defi Link Control Unit
Defi Amber Metric Boost Gauge
Defi Amber EGT Gauge
NISMO R-tune Camshafts ($1500)
-Valve Cover Gasket 13270-8J102
-Valve Cover Gasket 13270-8J112
-Intake Manifold Gasket (2) 14035-8J101
-VQ35D Plenum Gasket 14033-AM600
-VQ35D Plenum Gasket 14032-AM600
-O-ring (2) 15066-31U02
-Sealing Ring 15066-5E510
-Oil Pan Gasket 11121-31U00
-Front Crank Seal 13510-31U00
-Lower Oil Pan Seal 11121-31U10
-O-ring 15066-31U03
-NGK Premium Platinum (6) PLFR6A-11
Old Aug 7, 2014 | 07:58 PM
Frankieg35's Avatar
Luv the audio and console.. Glws
Old Aug 7, 2014 | 08:15 PM
Urbanengineer's Avatar
Wow I want this so bad. I bought a g a few too many yeas early
Old Aug 7, 2014 | 08:45 PM
gmotion04's Avatar
Good luck with sale! I bought some spacers from him a few years ago. Good guy.
Old Aug 7, 2014 | 08:51 PM
guitarrocker98's Avatar
GLWS AWESOME build!
Old Aug 7, 2014 | 08:56 PM
ScraggleRock's Avatar
Sell yours and buy this one. :P
Old Aug 7, 2014 | 08:57 PM
That center console is legit tho. Where did you even get that? You make that shib?
Old Aug 7, 2014 | 09:02 PM
Its a custom job!!! I know a guy who can make it!
Old Aug 8, 2014 | 12:39 AM
I know a guy that can make a matching rear one too... Surprised it wasn't standard.
Old Aug 8, 2014 | 12:54 AM
ChrisKG35's Avatar
Ultimate sleeper, woulda been perfect if it was 6mt.. GLWS
Old Aug 8, 2014 | 04:32 PM
kday's Avatar
The entire car was stripped down and dynamat was layed within. The interior is custom, done at the the same shop that did the enclosed sound system and the center console, center display and window switch panels were all fiberglass and painted to match.
Old Aug 8, 2014 | 04:34 PM
kday's Avatar
The car will come with 1 free pair of spacers! (already installed in the front)
Old Aug 8, 2014 | 04:36 PM
JaE35's Avatar
Moderator
G35 Sedan
Great build
Old Aug 8, 2014 | 04:44 PM
Hey, if you made that center console does that mean you matched the interior "aluminum" paint? I would loooove to know what you used.
Old Aug 8, 2014 | 04:57 PM
kday's Avatar
All of the aluminum colored parts in the interior were painted silver sparkle to match the amplifier tray in the rear.
