FS: 2005 IP COUPE 6MT Volk HKS Stillen Motordyne Osiris Custom Sound & More $18K INVESTED
Old Feb 18, 2017 | 04:48 PM
ryno824's Avatar
05 G35 IP Coupe HKS Stillen Motordyne Osiris Tune Custom Sound $18K INVESTED Reduced
Up for sale is Pearl my 05 Fully loaded Ivory Pearl 6MT Coupe Just turned 105K on the OD which is nothing on the VQ especially when maintained as this one has been. I am the original 110% non smoker adult driven owner and purchased from Clear Lake Infiniti with 58 miles on the OD. Still have window sticker. Has been Meticulously & over regularly maintained. Went the extra mile & had motor oil analysis done in the early years through Blackstone laboratories to see how the Break in period was coming along & which fluids filters matched the VQ the best
Driven to 10K HWY City mix w/ the factory synthetic blend so seals rings set properly then made the switch to full synthetic & as of this day I'm proud to say she has absolutely ZERO % leaks & super low consumption
As I've traveled from San Fran to Miami few times over & after adding up miles I'd say 80% of the miles are HWY miles. 1st 7 years was garage kept & only seen the asphalt on non rainy days as I had 2 daily's Only after that she hit the roads for the long hauls (Biz/Pleasure/Moves). Will be able to tell by looking at the under carriage as it looks like 5yr use vs 11
CarFax wise - Vehicle has never been wrecked but had a run-in in a parking lot w/ a parked SUV that had a hitch luggage rack that I could not see at night. The rack caught the passenger door & rear qt panel. Filed a claim & all the for-mentioned was fix & repainted perfectly to match the IP paint code. Also at this time I had bumper / lip repainted & the Gialla grill in gloss black. Front end looks immaculate
Few Negatives
Dash above glove compartment is cracked due to sound system install while removing the aluminum strip that runs across dash. Cracks spread overtime
Interior - The common small tear in driver seat, corner left hip / back area that's practically inevitable. No other rips or tears throughout. Seats covers as seen in pics included
Factory fix
Dual cooling fans
Driver side window motor
Suspension parts
Wheel bearings
New black OEM floor mats
Volk Time Attack TE37
19x9.5 +22 19x10.5 +22
Volk Lugs
Continental DWS Extreme 245/35ZR19 285/35ZR19 Plenty of tread left.
Stillen XD cross drilled rotors installed at Stillen. New pads installed last month
Tein S Tech
SPC Front alignment arms.
SPC Extreme rear camber arms w/ toe links
Eibach pro alignment completed at Stillen
Headlights NEW
Morimoto XSB Colorshift L.E.D. halos remote control w/ numerous color & transition options Flash Strobe Fade Smooth w/ speed options
H1 HID Headlight projectors
HID Shrouds in IP. Blackout housing
Clear corners smoke overlays Piaa Hyper whites
Taillights
Lightly smoked L.E.D. cuts outs. State legal.
Lightly smoked 3rd brake / Spoiler lights L.E.D. cuts
Roof / hood wrapped in gloss black vinyl. Not painted so removable option
Gialla grill
GoPro video camera tether mounts, removable
UpRev Osiris ECU Reflash Tuner 3 maps. Dyno tuned at UpRev facility in ATX
HKS Hi-Power Titanium True Dual Exhaust
NOT a replica have receipt from Stillen w/ Dyno sheet
Ztube K&N
Berk Technology HFC
Motordyne 5/16 ISO Thermal Copper Plenum Spacer
NGK Platinum plugs
Amsoil synthetic rear end 75w90 severe gear GL5 & trans w/ 75w90 GL4
Stillen lightweight crank pulley & belt set. STD lightweight pulley. Installed at Stillen
ACT HDSS Stage 2 High Performance Clutch / Aluminum Flywheel kit
ACT Heavy Duty Pressure Plate w/Street Disc
Aluminum High Performance Flywheel
Throw Out Bearing
Pioneer Z140BT Flagship 800x480
Double din
Alpine 6 3/4
Alpine 6 1/2
JL Audio 10W7AE-3 Anniversary edition 1500wt
Kicker ZX 750.1
Alpine MRPF 300.4
Stinger 5" cooling fan
Cabinet grade plywood (Zero flex) ported enclosure tuned to 32hz wrapped in Wheat leather to match the wheat interior. 5/16 Plexiglass window (Zero leakage). False floor w/ mesh breathable material (The black in the JL Logo and also in rear deck above the W7 & port) amp cover wrapped in same material, easy access to amps. False side panels to gain access to back seat release that was relocated. L.E.D. lights around enclosure & inside enclosure as well. The JL is firing up inside the cabin and reflecting off the rear window instead of inside the trunk, nets the truest of sound waves and SPL & a nice benefit is the ears on the outside don't have to hear all that trunk rattle as w/ the traditional trunk enclosures. Side note- The enclosure itself is suspended above the floor with 5/16 steel brackets drilled into the frame of the vehicle so there is absolutely ZERO play during any hard cornering & the like. Also adds security encase any undesirables come along
Battery
YellowTop SpiralCell Deep-Cycle D35
Deep-cycle and cranking power
Up to 3X longer life
15X more vibration-resistant
Virtually spillproof
Mountable in virtually any position
Maintenance-free
Faster recharging
Optimal starting power
300+ discharge/recharge cycles
Pearl has been a true joy to own, tune & drive from every coast in the US, she has never left me stranded. It's now time to part ways with Pearl though as looking for a new project to start
Side note for your insurance / piece of mind: The UpRev Osiris full ECU re-flash I chose a map for security where with a simple input code the car will be fully immobilized. There's actually another security measure & the (2) will be revealed only after the title is signed over. Both are nice security measures that could save you $$ on your premium
Clean and clear title, complete service history & will supply the purchaser with all documents & receipts
Overall I'm confident that miss Pearl here is one of the cleanest & well kept G35's out there on the market. Must see, hear & drive to really appreciate
For those that DO NOT know how to drive a 6 please don't waste your time or mine as I DO NOT have the time to give a crash course. NO JOY RIDES.
Over $18K invested Asking $13,300 REDUCED $12,900
Vin: JNKCV54E95M423191
Ryan 361-742-6775 Austin TX groupon66@gmail.com
screen grab
image uploader
image sharing
upload a picture
online photo sharing
imagur
temporary image hosting
img host
post image online
image hosting
images upload
photoupload
host image
uploading pictures
free photo upload
images upload
pic host
upload image free
upload gif
free photo hosting
20mb image hosting
images upload
