FS: FS: 2005 G35X Sedan uprev tuned + shift kit in Missouri
Old Jan 16, 2020 | 08:02 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
I am selling my 2005 Infiniti G35x all wheel drive. It has 166,xxx miles and I currently drive it everyday. It is very well maintained and originally a Texas car so NO rust at all and does not leak anything. This car runs perfect in every way and won't need any maintenance for quite awhile. It also has tinted windows, remote start and keyless entry. I have upgraded the brakes and added a cold air intake kit with silicone tubing to replace the old rubber intake tubing that cracks and is a common problem on these cars. The only thing that doesn't work on this car is the TPMS tire pressure sensors that warn you for a low tire, the batteries in the wheel sensors are bad.
It's a little dirty right now but once it warms up I'm going to detail the interior.
List of maintenance / upgrades in the last 1.5 years
New OEM Nissan cam sensors
New OEM Bosch primary O2 sensors
New NGK spark plugs
New front CV axles
New front driveshaft (prop shaft)
New radiator
New front wheel bearings
Upgraded M35 big brakes
New drilled / slotted rotors
New ceramic brake pads
New tires
New Valve cover gaskets
New oil cooler seals
New injector O-rings
Whiteline poly mix lower LCA bushings
New 6000k HID pure white headlight bulbs
Transgo Shift kit
Transmission flush - New fluid
Cold air intake
Uprev tuned - Almost as fast as my stock HR sedan!
7" Android radio / video player
Remote start / keyless entry
Asking $4500
Old Jan 17, 2020 | 12:11 AM
Jeremy14ynwa's Avatar
How do you like the Transgo shift kit? Notice much of a difference after you had it installed?
GLWS nice looking car with all the hard maintenance items knocked out of the way for whoever buys this!
Buy it and go like hell!
Old Jan 17, 2020 | 07:29 AM
It helps a bunch. I have used it on both generations of the RE5 transmissions and it take the glide out so it's a nice firm shift. Who knows how much longer the transmission would last if this was done early in life.
Old May 18, 2020 | 01:17 PM
Car has been sold
EPiK
Feb 3, 2018 06:42 PM
92drls
Drivetrain
Aug 16, 2017 05:40 PM
robert1911
Drivetrain
12
Feb 16, 2016 04:24 PM
papiloco21
Jun 14, 2007 10:34 AM
