FS: 2006 G35 6MT coupe turbo
Old Dec 8, 2020 | 09:08 PM
grimvanni's Avatar
G35
This is my project car that I have been working on for 1 year and put some work into to get it where I wanted it. After the turbo was put on it only brought to light some underlying issues. I was looking into building and going forged but with funds running out, I could use the cash rather than hold onto it unfortunately.
The turbo:
Rev9 turbonetics style turbo
Bosch 550cc injectors
Walbro 255
1 step colder plugs
UpReb base tune by RZG motorsports on 6 psi
AEM Oil 0-150 psi gauge
AEM Wideband
AEM Boost gauge
A/C system still intact and works
The motor:
140,XXX miles
Has oil leak in the rear of the motor, unsure where its coming from still holds 70-80 psi on start up and 15-20 psi at idle
- Oil leak seemed to be coming from rear upper oil pan seal. Replaced front and rear upper oil pan seals and RTV'd the oil pan back in place
Valve cover gaskets replaced with Maxima valve covers 100 miles ago
Rear main seal replaced 8k miles ago
Smokes under boost, I suspect its internal somewhere (rings?) (Oil restrictor was a bit too big, installed smaller restrictor. 0.035" and smokes a lot less.)
- Oil return line needed to be relocated above the oil level. Oil wasn't flowing back as it should have causing oil blow by. Blocked off oil pan spacer and tapped upper oil pan above oil level for oil return.
- Oil Catch Can will be installed to further reduce amount of oil in the intake.
Motor isn't knocking, and runs fine, other than the two listed issues above that should have been resolved will post update once a test run is complete.
Transmission:
Stock clutch replaced 8k miles ago
Shifts smooth
No grinding or chatter
Trans oil replaced 8k miles ago
Suspension:
All stock
OEM 19" Rays will be included, sitting on 20" chrome wheels for the winter.
Exterior:
Some dings here and there
Paint chip near front driver side headlight (got backed into in work parking lot and no info was left...)
35% Window tint all the way around
Dual N1 mufflers with a Borla Pro XS muffler
Interior:
Double din Apple car play compatible radio
Bose sound system
Small tear on corner of driver side seat
Motorized seats work fine
Seat heater works fine
Dash has cracks
Price:
$7500
I hope I captured everything I could about the car, if there are any other questions or anything else I should add let me know
Old Dec 10, 2020 | 08:27 PM
Zach C's Avatar
Looking to Buy
I am interested. Joined to reply, don't have DM privileges. Is there a good way to get in touch? Where is this located?
Old Dec 10, 2020 | 09:08 PM
grimvanni's Avatar
G35
Its located in the Hampton Roads Area in Virginia. Im
not sure what the rules are for contact information and such on these forums.
Old Dec 10, 2020 | 10:45 PM
Zach C's Avatar
Looking to Buy
Nice I'm down in Wilmington, NC so not too far. Have any pics? Will hopefully be able to DM soon.
Old Dec 11, 2020 | 04:30 AM
grimvanni's Avatar
G35
for some reason the embedded pics don’t work right, here’s the link to the pics
https://imgur.com/a/e1qwgAF
Old Dec 11, 2020 | 12:09 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Did you try to post the image url to embed (using the photo attachment tool) or were you directly uploading pictures?
Old Dec 11, 2020 | 01:28 PM
grimvanni's Avatar
G35
I think I got it to work, could you verify please?
Old Dec 11, 2020 | 02:37 PM
G2B35AGN's Avatar
Yep, working now. Last thing is a verification picture is needed: username and date with car in image.
Old Dec 11, 2020 | 04:33 PM
grimvanni's Avatar
G35
Uploaded, let me know if it is viewable.
Old Dec 11, 2020 | 05:36 PM
G2B35AGN's Avatar
Yep, all good now. GLWS!
Old Jan 13, 2021 | 04:16 PM
grimvanni's Avatar
G35
Price reduced!
Old Jan 24, 2021 | 08:43 AM
kel's Avatar
kel
you should put it on the facebook marketplace, someone will buy it flying
Old Jan 24, 2021 | 07:44 PM
grimvanni's Avatar
G35
I have it on FB marketplace but with the two issues listed, people are reluctant to want to buy.
Side note, I replaced a few parts and am looking at getting it fine tuned in the coming weeks. Will post update once tune is complete.
Also Bump
Old Mar 27, 2021 | 09:34 PM
Totvbox Pro's Avatar
Nothing yet
Did you get this sold?
Also Bump
Did you sell your car? I've been looking for a turbo or supercharged g35. Please let me know. Thanks.
Old Mar 27, 2021 | 10:42 PM
grimvanni's Avatar
G35
I have not, I’m in the process of building a motor for it. But if you’re interested we can work it out.
