--- SOLD SOLD SOLD ---
Clean title, Florida car, no rust, no mechanical issues, non smokers, no pets, adult owned and not abused. Bought it with 126k miles and did a lot of work to it.You can drive this car where ever there are roads, there is nothing wrong with it mechanically. There are many threads on here about this car.
Located in Princeton, Florida 33032.
Asking $6,500.
Here is the list:
-Replaced timing chain guides, seals, oil gallery gaskets, o-rings, water pump and tensioner from Z1 Motorsports on 03/24 @ 126k miles.
-370z Nismo shocks and struts with springs 03/24
-Android Auto Radio
-Replaced BCM 03/24
-New brake booster 03/24
-New rack & pinion 08/24
-New tie rod ends 08/24
-New front control arms 04/25
-Brake fluid flushed 05/24
-Transmission serviced 03/24
-New sway bar end links 03/24
-New driver side wheel hub 03/24
-Akebono big brakes from Q50 installed 04/25
-New camshaft position sensors 03/24
-New coolant temp sensor 03/24
-New coolant tank 12/24
-New cooling fan module 03/24
-New crankshaft position sensor 03/24
-New engine and transmission mounts 04/24
-New engine pulley bearings 03/24
-New front bumper grille 04/24
-New fuel pump assembly 03/24
-Upgraded 80W LED headlight bulbs 03/24
-New Hitachi ignition coils 04/24
-New PCV valve with hoses 03/24
-Rear 3.53 VLSD diff swap from 370z 03/24
-Rear ducktail spoiler 04/24
-20x8.5 Spec-1 wheels installed with new tires 12/24
-New 6 Denso Iridium spark plugs 05/24
-Fixed sunroof drains with new tubing 03/24
-New thermostat 03/24
-30% Window tint 03/24
-XPO black carbon fiber wrap on hood, roof, trunk, side doors and interior. 03/24
-White OR Yellow LED fog lights switchable by wireless remote control. 03/24
-2.5" cat back exhaust with Helmholtz resonators installed 04/25
Here is a link to my youtube channel video clip of how it runs. This is a cut from the original Helmholtz Resonators video:
