Front Grill Question
Old Jun 30, 2006 | 02:59 AM
SpeedNStylez_JL's Avatar
Hey guys I was wondering if the 03-05 G coupes had the same front grill as the 06 G coupe? I bought a aftermarket fiberglass grill and it seems to have a big gap on the sides and bottom when I tried test fitting it...
Old Jun 30, 2006 | 03:25 AM
truplay8's Avatar
THE BATMOBILE
im pretty sure there all the same.........k67 has an 06 and aftermarket grille and his fit perfectly........maybe its the grille itself
Old Jul 6, 2006 | 09:38 PM
mkn1620's Avatar
i have the same problem, did u solve that problem yet?
Old Jul 6, 2006 | 09:46 PM
extreme4377's Avatar
Lexus IS350
Must be luck of the draw. My Silvia Parts Gialla Style grille fits perfectly! No gaps bigger than maybe a few mm on the sides but when I installed it I made the gaps even on each side.
I have an 06 and the grill is the same as any other year.
Old Jul 6, 2006 | 09:56 PM
mkn1620's Avatar
is it possible u can take a pic of it?
this is what happen. when i insert it in. it cant insert from below. i inserted it from the top....
Old Jul 6, 2006 | 11:43 PM
No, still no luck. Whats worse is I already painted mine before test fitting. I also have no mounting points on the bottom of the grill only the top...
Old Jul 7, 2006 | 12:36 AM
Lexus IS350
Always test fit before painting. It can save you money in case A. the grill doesnt fit and you can exchange it for a new one and B. in case you scratch it while installing it
There are no mounting points on the bottom of the grill, theyre not necessary. Some people use double-sided sticky tape but I chose not to and its plenty stable without
jsimonk
Dec 22, 2023 03:49 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
realtalk21
Jul 20, 2015 09:07 AM
