Metal Grinding noise, not abs.
Old Jul 6, 2006 | 03:46 PM
dukieman23's Avatar
or at least i dont think its the abs.
I have this really nasty metal grinding noise coming from either the front left or the back leftmtire area when my car is moving 15-20mph, especially when i steer a little to the right. It creeks and grinds loudly even when the car is warm, I got off the freeway this morning thinking it might be because of the cold start, but the noise still persisted everytime i steered a little to the right. Dont know if it can be a pebble in the brakes as i have read someone had. Mine is an 06, w/ 3500mi on it, so it shouldnt be in need of a rnew otor replacment...have a scheduled service for next wed since they are out of loaner cars until then. anyone experience soemthing similar?
Old Jul 6, 2006 | 08:29 PM
TonyK's Avatar
I had something like that - turned out that the brake pads needed replacement. But at 3500 miles?
Old Jul 7, 2006 | 10:14 AM
Gashed's Avatar
Could be a damages brake pad, or even a cracked brake pad. Have it checked out or check it out yourself.
Old Jul 7, 2006 | 12:45 PM
LEK's Avatar
LEK
That Guy
a member on here actually had a debris from the road get caught between the pad and the rotor and it was scratching the rotor up.... you need to get it checked out.
Old Jul 7, 2006 | 03:02 PM
CERTAUTOG35's Avatar
That actually sounds more like a hub bearing especially since it makes the noise when you turn the wheel
Old Jul 7, 2006 | 04:56 PM
Msedanman's Avatar
O.F. Administrator
Brakes would be my guess too.
C.
Old Jul 7, 2006 | 05:16 PM
gametox's Avatar
when i had a civic, when the power steering fluid was low, it would do the same.
When i turned the steering wheel, it would make lots of noise.
Might want to check your power steering fluid level.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
prinny
Nov 22, 2015 11:07 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
