how low is to low?
Guest
Posts: n/a
how low is to low?
ok so im currently gonna try and go cheap and order some lowerin springs for me car but im not sure the springs that im looking at the drop in the front is 1.6 and 1.4 in the rear...for the people that have the lowered gs how low is to low before it starts rubbing?
It'll look sick BUT you'll be WAY outta factory camber specs. At that low I think rubbing will be the least of your problems. You will have dramatic inner tire wear from the camber issue. You will also most likely tear the steel braided "flex" area of your exhaust. This area of the exhast represents the lowest point of your car and first to "scrub" on speed bump etc.
How do I know. I had my coilovers that low for about 48hours before I got tired of worrying about every damn dip and bump in the road, it looked cool but sucked to drive.
Wow, that's going to be quite low. Can't do that in these parts. The city is riddled with potholes.
If you are in anyway concerned with tire life and wear, you will need to get front and rear camber adjusting components.
Originally Posted by mr freeze
im running 19's and i have a 2" drop..no rubbing or camber issues what so ever...
