Need Help with Tire Rub!
Hello all. I need some advice about tire rub. I recently had DPE 20s installed on my coupe. Suspension is stock. It looks great, but I get tire rub on the front wheels whenever going over bumps/uneven road surfaces at high speeds. I cringe whenever it happens.
How do I fix this? Roll the front fenders? New suspension? I appreciate any input that I can get as I am rather new this. Thanks!
theres alot of things you can do, its about how much do you want to spend. i suggest rolling the fenders or cutting the lip off. next step is to get coilovers on it, and get it stiff. then after that you could Tub the wheel wells. but given i dont have a g35 sadly i dont know if you have space for that. hope this kind of helps.
mk-
mk-
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
