some help needed removing the center console
Old Oct 17, 2006 | 02:00 AM
custom_bimmer's Avatar
got an 06 g35 and i need to remove the center console. please help.
thank you,
keegan
Old Oct 17, 2006 | 02:08 AM
kennyz424's Avatar
im not sure how too but do you mind me asking why you need to move it lol
Old Oct 17, 2006 | 09:01 AM
g35rcr's Avatar
remove the clock covering, there are 2 screws that hold in the clock assembly remove those, then behind that there is a main screw that holds down the radio remove that. next remove the trim pieces at the bottom of the steering wheel to access the screws there and the side molding next to the radio. repeat the same on the passenger side but remember to remove the right footwell carefully there is plastic nut thats on the top. remove the glove box assembly and do not unplug the airbag sensor. remove the side trim then remove your shift console area to get the last 2 screws that hold in the stereo
Old Oct 17, 2006 | 09:18 AM
gqong's Avatar
^^ sounds like you are posting the removal for a 03-04 the 05-06 can be found here...
https://g35driver.com/forums/audio-video-electronics-diy/90507-diy-06-hu-removall.html
Old Oct 17, 2006 | 08:28 PM
i need to remove it to get to the airbag module.
thanks guys.
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
Cacoepy
Aug 3, 2015 01:09 PM
