camber kit specialist plz help
Old Oct 28, 2006 | 12:35 AM
MaRu's Avatar
I have Hks rs coilover and volks winning offset +17 for the rear..
toyo t1 r 285/35..dropped about 2 inch.. and i rolled the fenders already..
If I correct the rear camber, will my tires rub the fenders?? because having
positive camber.. I dont want to raise my car ... love the drop now.. but i
might change the tire size to 275/35.. i just want to know if i can fix my
rear camber without raising the car..
i'm planning to purchase spc rear camber kits..
Old Oct 28, 2006 | 12:39 AM
EricIsKlumzyee's Avatar
I think you mean u have negative camber..
Negative camber / - \
Postive camber \ - /
If you just dropped then you have negative camber and toe out.. IMO get the SPC toe bolts and u'll be able to put your toe back into place.. running 285/35 will cause you to rub if your cambers back in spec.. if you run 275/35 you should be okey..
- Eric
Old Oct 28, 2006 | 10:11 PM
ZeroGen's Avatar
Omega Enthusiast
Whoa...+17 offset on the rears is pretty aggressive. Depending on how close you are already with the 285s, running 275s may or may not help considering you're only decreasing the tire width size (on the outer side) by 5mm.
Old Oct 28, 2006 | 10:34 PM
mark4x4's Avatar
How wide are the rear rims?
Old Oct 28, 2006 | 11:42 PM
castertroy101's Avatar
- Eric
thanks for posting the diagram. I was confused for awhile about what a negative camber set up was suppose to look like.
Old Oct 29, 2006 | 09:54 AM
alfunky99's Avatar
hey guys!! i plan on getting the eibach pro-kit installed. my question is that will i need a camber kit??? do anybody know.. the drop is not much..1 inch in the front and 1.1 in the rear.. thanks in advance
Old Oct 31, 2006 | 09:17 AM
LazerRed1's Avatar
Probably. My understanding is that only Tein H will adjust back to factory specs w/o kit. Less drop, but less $$$$.
Old Oct 31, 2006 | 09:50 AM
dream_G35's Avatar
i have the same rim/tire set-up as the guy who started this thread and dropped on tein h-techs (i roller the fenders and its fine) i want about half an inch more drop all around how can i do this without sacrificing the progressive(i think) springs that the z htechs are?
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
mikemf8
Sep 3, 2015 08:01 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
