Ordering rims need to know what offset i need.
Old Oct 28, 2006 | 11:39 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by pp7
Hey I just ordered a set of Ruff 277's for my '05 sedan. 8.5 - 245/35/19f, 9.5 - 275/30/19r, +35 offset all the way round. Will these be inline with the fenders or tucked? If tucked what size spacers will I need?
You definitely wont need spacers. The front will be perfectly in line with the fender. The rear however... that is a quite agressive offset for a 9.5" wide wheel. I have +45 and it is a tad inside the fender. The +35 on the rear is going to stick out, and depending on how you feel about the look, you MIGHT have to run an excessive amount of camber to make it look right.
-GP-
Old Oct 29, 2006 | 01:15 AM
pp7's Avatar
pp7
Can offsets be adjusted? I remember them saying something about "35 to 38mm". Does 10mm make that much difference? And what is camber?
Old Oct 29, 2006 | 06:12 AM
Nismo G's Avatar
Your camber is how much negative or positive your tires are angled. So if you have a negative camber your tires are going to ride un-even with more weight on the inside of the tire. If you have no camber the tire will ride perfectly flat and if you have positive camber your car is going to ride more on the outside of the tire. Our cars have a negative camber which is why the inside of our tires wear faster than the outside.
Old Oct 29, 2006 | 07:04 AM
Nismo G's Avatar
Also, does anyone have pictures of a coupe with 19x9.5 rear with the +35 offset??
Old Oct 29, 2006 | 01:34 PM
pp7's Avatar
pp7
^Thanx man! Can offsets be adjustable? Does adjustable mean adjusting the camber?
Old Oct 29, 2006 | 01:45 PM
Nismo G's Avatar
You cant really adjust offset, its the way the wheel is built. I think you can add spacers behind your brake rotor and it will allow the wheel to stick out however much further (kind of like adding washers on a screw and then tightening it...the screw wont go in as far due to the washers adding the extra space).
Camber can be adjusted, but not with the factory arms toes and cambers. You would have to go aftermarket (stillen for example) and they make adjustable parts... so you can either have no camber or you can add negative camber to the car.
Old Oct 29, 2006 | 01:48 PM
speedracerg35's Avatar
try this. it will tell you how much farther in or out your wheel and tire will sit.http://www.1010tires.com/WheelOffsetCalculator.asp
Old Oct 29, 2006 | 01:54 PM
lowrider's Avatar
I have the 18" LMGT4s with the same offsets. IMO, offsets are perfect You'll be just fine.
Remember these are Nismos that Nissan recommends for the Zs and Gs.
Lou
Old Oct 29, 2006 | 02:07 PM
pp7's Avatar
pp7
Lou
So you have a rear 9.5 +35 on a sedan and it looks fine? Doesn't stick out at all?
Old Oct 29, 2006 | 02:12 PM
Nismo G's Avatar
Lou
Are yours on a sedan or coupe?? Also, are yours +35rear and +25 front??
Old Oct 30, 2006 | 06:55 AM
lowrider's Avatar
How did we start talking about sedan? The original question concerned a coupe. I have a coupe. Wheels are on a coupe. Fit Great on a Coupe Rears are +30mm, fronts are +25.
Why did this thread get so mixed up. When a thread starts out talking about a coupe - Keep it about a coupe. Sedan - Keep it sedan. Two different cars. Stop mingling different models in the same thread. I was responding to the ORIGINAL question.
Lou
Old Oct 30, 2006 | 07:09 AM
Nismo G's Avatar
Lou
HAHA thanks loud. I was red your post 3 times and was wondering where you said sedan at.....i guess that kid was making things up.. B ASTARD!!
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
Machine Head
Sep 4, 2015 07:22 PM
mikemf8
Sep 3, 2015 08:01 PM
