Problem with CD player
Old Nov 3, 2006 | 02:10 AM
insydiusg35's Avatar
Hey guys, today I started my coupe like regular and everything went fine until I changed my CD option to the AM/FM option, but found that nothing good was on the radio so I switched back to CD. Then all I heard was the sound of the changer changing tracks repeatedly for a good 20 seconds and then stopped. An error message came up on the screen, "CD ERROR FO." I turned the power off and turned it back on but again, it made the changing sound then went to CD ERROR FO. I even tried turning my car off, but to no avail... Has this happened to you guys before? What should I do? Would this be a stereo warranty issue? Your imput would be greatly appreciated.
Old Nov 3, 2006 | 02:12 AM
LjN_728's Avatar
Have you tried putting in a new cd?
Old Nov 3, 2006 | 02:25 AM
I already have all 6 slots filled with my cds, but I will give it a try.
Old Nov 3, 2006 | 02:35 AM
Spedizzo's Avatar
I had this problem except it said F3 and not FO. No CDs would work, I would just hear grinding followed by that error. I had Infiniti replace my CD player.
Putting another CD did not work. Even if I tried pressing the Load button, all it did was "beep"
Old Nov 3, 2006 | 02:37 AM
Alan's Avatar
great, yet another broken cd player thread. warranty it!
Old Nov 3, 2006 | 02:39 AM
Sukairain's Avatar
Mine finally did this after almost 4 years. Vintage G's had this issue a long time ago in 2003. I was going to get the changer replaced and then next day voila~ everything back to normal. Who knows. I was kinda hoping they would replace my unit with one that is MP3 capable.
Old Nov 3, 2006 | 10:44 AM
castertroy101's Avatar
yes your CD Player is broken ....Go to the stealership and get it replaced under warranty. Mine is already on boarder of going out. It started skipping on songs when the car is not even shaking ....Hopefully i can get the mp3 version.. well at least i hope
Good luck with the fix.
Old Nov 3, 2006 | 12:16 PM
JBKFizzle45's Avatar
My cd players has spazzed out on me a couple times since ive gotten the car (I have an 06) I just shut the radio off, shut the car down, turned it back on and everything was back to normal. Not sure what it was but I havent had that problem in a while.
Old Nov 3, 2006 | 03:04 PM
OU812G350's Avatar
audio units have a warranty with INFINITI / NISSAN on an exchange basis..
Old Nov 3, 2006 | 03:59 PM
ukgt's Avatar
Mine is Japanese spec but in the hand book it says that the cd player is protected against condensation and water vapour in certain climates. I emailed nissan helpdesk in Japan, as Nissan in the UK know Jack Sh*t about the car, and they told me to use the thin nozzle attachment of a vacuume cleaner to suck the moisture out of the cd slot. Did this and after a week of it not working it worked straight away and no problems since.
Just so you know they also told me not to use blank cd's written on your pc as a lot of the makes are thicker than the legal copys and not to use any with stickers on like the labels you use to id the cd with.
Might be worth a try. Has the weather been damp where you live, ie windscreen keeps misting up ?
Old Nov 3, 2006 | 05:10 PM
vt_maverick's Avatar
The first thing you should do is use the search button on this site.
Old Nov 3, 2006 | 06:42 PM
ukgt's Avatar
If search buttons were used all the time we wouldn't have new or up to date solutions. Easy anwser is the clue is in the thread name ie cd problems, if you have nothing to add dont open the thread .
Old Nov 3, 2006 | 10:05 PM
No, if search buttons were used we wouldn't have thousands of duplicated thread topics. The reason nobody searches anymore is because there's so much crap out there that you can barely wade through it all to find what you need. Want an example? Search for anything to do with the CD player or air intake. You get hundreds of hits, all of which say almost exactly the same thing.
I'm not trying to be a d1ck here. People just need to realize that there are bigger side effects to reposting (at least on car-related issues) than just annoying older members. Posting the same question over and over again is not the way to uncover new answers; encouraging members who've made a valuable new discovery to post their findings (after they've searched of course) is.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
mattdg35
Sep 14, 2015 11:28 AM
Jnm07
Sep 5, 2015 01:16 AM
