How do i know if my car has RAS?
Originally Posted by drive4fun
There's no other way to see if you have RAS? Hmmm.. There has to be any easy way to find out..
Originally Posted by cnaman
do a quick lane change back and forth. if ur car whobbles and feels like a boat, then u do not have rear active steer.
Originally Posted by mart182003
hahahaha how fast should he drive im thinking 120 mph would be a good test. lol
i have 05 g35 6mt coupe, and i have a RAS sign on my dash which never comes on (not even when i start the car first time.) i see people saying 05 models doesn't have RAS i do have the light place but doesn't turn on do i have a RAS? or not?
Even if they turn in opposite directions body lean will still be reduced some what because part this imparts a rotation about a point that is somewhere on the centerline of the car (along its length). This type of rotation also does not cause body lean.
6MT Coupe
From my 06 Owners Manual:
'The Rear Active Steer (RAS) system is an electronically controlled four-wheel steering system.
The angle of the rear wheels are adjusted by the RAS system, depending on the vehicles speed and steering angle. The rear wheels are designed to turn momentarily in the opposite direction and then change to the same direction as the front wheels.
At low speeds, the rear wheels will not turn and the system functions as a two-wheel steering system.
