Brembo Brake Job
Old Jan 2, 2007 | 10:55 AM
Maximus's Avatar
Brembo Brake Job
Bought Hawk HPS pads F & R for 04 coupe with brembos.
Question is, what do I do about the rotors. I see some say they should be resurfaced, other say that Brembo rotors are never to be resurfaced.
Normally I wouldnt resurface the rotors, however, I noticed some "heat" marks on the front left rotor, all the other rotors look perfectly normal though, and car breaks great, no vibration so they are not warped.
Will light sanding return rotor to normal, or is it imperative to cut the rotors.
Or do I just leave it ?
Old Jan 2, 2007 | 03:42 PM
AuAltima3.5's Avatar
Hurm...
How much are the brembo rotors for this car? Unfortunately, they will be coslty and is the correct way is to replace the rotors to do the brakes on this car (any car really).
I am sure you could find a shop to cut them, but the cutting reduces mass and perhaps the integrity of this rotor, if it wasn't designed for this. Check the FSM for this. If that says the rotors can be turned, then you can do that.
Old Jan 2, 2007 | 03:49 PM
Aman's Avatar
Don't sand them, they either have to be cut a few thousandths or replaced. Hotspots like you describe will hurt that rotor's effectiveness at displacing heat and grabbing the pad, so not a great idea to leave alone.
Old Jan 2, 2007 | 03:50 PM
fabulustt7's Avatar
my brembos were turned, but the dealership said to replace them, but my mechanic said he turned his brembos on his porshe so i jus got them turned they feel like normal now too
Old Jan 2, 2007 | 03:53 PM
6MTFTW's Avatar
According to the FSM, "If thickness is outside the standard, replace disc rotor." There is no mention of resurfacing the rotors. That, and according to their specs, only .062" can be worn/milled off.
-Jerome
nissandrifter32
Dec 22, 2015 04:28 PM
alessandro
Oct 8, 2015 09:29 AM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
NJ6MT
Sep 10, 2015 08:40 AM
