Quick lowering question
Old Jan 9, 2007 | 02:30 PM
t67supra's Avatar
Should I be able to run a 275/30/20 in the rear on a 10in wheel, and 245/35/20 in the front on an 8in wheel, lowered 1.3"F and 1.1"R??? Thanks alot for any help.
Old Jan 10, 2007 | 04:23 PM
t67supra's Avatar
anyone???
Old Jan 10, 2007 | 05:08 PM
redlude97's Avatar
whats your question exactly? Tires should fit on those sized wheels okay, but the 8" in the front is a little on the narrow side for a 245. If you are asking about rubbing, then depends on your offset
Old Jan 10, 2007 | 09:37 PM
G&Z's Avatar
G&Z
i got 9.5 in rear and 8.5 in front and am running 275 35 19+ 245 35 19. if you lower an inch you want to look into camber adjustments. other than that you should be fine... tires should not rub.
Old Jan 11, 2007 | 12:58 AM
jdmeg21's Avatar
I'm running 10.5 275/35/19 - 8.5 255/35/19 with 1'' drop and I'm fine.
Old Jan 11, 2007 | 01:48 AM
redlude97's Avatar
No one's listing offsets, that the most important part of the equation when it comes to rubbing. Its already well known that 9.5F and 10.5R fits fine with the correct offsets using 245/255 up front and 275/285 in the rear. People rub when they want an aggressive stance with low offset wheels.
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
