Blown tire took a chunk of wheel!!!
Old Jan 10, 2007 | 08:55 AM
fcarpio's Avatar
Hi all,
I know this will be OT, but from previous experience I rather deal with the flamers here than with the best the BMW forums have to offer.
I friend of mine has a 2005 325i and it is still under warranty. A blown tire somehow took a chunk of wheel's lip, about the size of the lead weights that are used to align them. The piece of metal blew out when the tire exploded. The wheel did not touch the road since these bimmers come with run flat tires. Obviously the integrity of the wheel has been compromised and don't think she should be driving her car like that. The dealer (Vista BMW on Coconut Creek) replaced the tire, but left the wheel as is. She asked if it was safe to drive, and off course they said it was OK. I differ.
Does anyone have any ideas on how to handle this issue? Please help.
Old Jan 10, 2007 | 08:57 AM
Mark350GT's Avatar
they should replace the wheel. I can't believe that a tire blowout would blow a chunk of the wheel off.
Old Jan 10, 2007 | 09:24 AM
Peter NY's Avatar
I would make them replace it since it has full maintenance and a warranty.
Old Jan 10, 2007 | 09:35 AM
gspotter's Avatar
Please post a pic if you can.
Old Jan 10, 2007 | 10:31 AM
fcarpio's Avatar
We carpooled today, so the bimmer is at my place. I will take a pic later on today to post.
BTW, our carpool of 4 has 2 Infiniti's. One 2007 Sedan and one 2006 Coupe (mine). We represent!
Potty_Pants's Avatar
have em contact the regional bmw mgr or national call center. if it looks like it occurred by a blow out a little leg work will prob get it replaced w/o cost. if it looks like road dmg or suspect over pressure, may be tough... but still could be covered.
ppp
Old Jan 10, 2007 | 10:50 AM
wilksoner's Avatar
thats rediculous if it really went from the blow out they sho replacing should be replacing it unless when it blew he hit somthing
Old Jan 10, 2007 | 12:23 PM
fcarpio's Avatar
It did not hit anything, the run flat tires prevented the wheel from touching the road!
Old Jan 10, 2007 | 12:36 PM
V35 Skyline GT's Avatar
6MT Coupe
Any part of the lip missing is not good/safe imo. There will be stress on the new tire bead where there's no bead lip. He needs a new wheel.
Old Jan 10, 2007 | 06:36 PM
fcarpio's Avatar
Here is the picture...
Pic
Old Jan 10, 2007 | 07:17 PM
AthensBlueG's Avatar
Brian
I can't imagine how a tire blowout would cause that, unless the rim hit the road. It's on the INSIDE of the lip. He might have hit something in the road that popped the tire and simultaneously chipped the rim. But rubber doesn't do that to a metallic alloy - it's just not possible.
Old Jan 10, 2007 | 07:24 PM
gspotter's Avatar
I agree with AthensBlueG. Looks like it is from road debris which damaged the rim and the tire at the same time.
Old Jan 10, 2007 | 07:27 PM
Jeff92se's Avatar
Red Card Crew
Just because the tires are run flats doesn't mean she didn't hit something that blew out the tire and took a chunk of the wheel also.
Old Jan 10, 2007 | 07:30 PM
6MT Coupe
Wow...the tire sidewall did that?!?!
Ok, the lip where the tire bead seats is intact, so I guess I can see where the Dealer would say the wheel is okay to drive on, but Dang, it looks like something else torn into that wheel. It's a weak spot now for sure.
Here's a side wall blowout I had and you can see where the tire bead flared the bead lip. I didn't hit anything on that one either. It was a sidewall failure with only 12 miles on the rubber. It blew going about 75mph on the freeway.
Those marks to the right are from a rock(s) I hit when pulling on the shoulder still going rather fast. They look at my tire and nothing pierced it, so they replaced the tire and wheel n/c.
Tell your lady friend g/l. Doesn't hurt to try to get the Dealer to replace her wheel if they can prove nothing hit the wheel/tire sidewall and make it blow out.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
obender66
18 Inch
Mar 13, 2016 12:20 PM
Fireman07603
Aug 9, 2015 06:00 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
