Brake light comes on under heavy braking...
Old Jan 11, 2007 | 02:45 PM
madchef's Avatar
Question Brake light comes on under heavy braking...
Whenever I step hard on the brakes, the red "brake" light comes on (same on for the parking brake)
I ran a search and the closest thing I could come up with was that my brake fluid might be low (I'll be checking it after work)
Can anyone confirm this? Or anyone had the same issue? Thanks.
Old Jan 11, 2007 | 02:47 PM
redwillow's Avatar
20 Year Member
yeah, your fluid is prob low and when you brake hard it is sloshing around in the mas cylinder setting off the sensor for the light. Add some fluid...make sure it is dot 3.
Old Jan 11, 2007 | 02:48 PM
OtisG35's Avatar
Yeah its low brake fluid. Probably just needs to be topped off.
Old Jan 12, 2007 | 02:00 PM
DaveG's Avatar
your brake fluid is low in the master cylinder because your front pads are worn ( the fluid moves down to fill the space in the calipers.)
replace the pads..
Old Jan 12, 2007 | 05:56 PM
jdmeg21's Avatar
low fluid
Old Jan 12, 2007 | 09:34 PM
NETSHARK's Avatar
Happened with me before, i`ve filled the brake fluid after 3-4 days i started to hear a BIG noise under heavy braking becuase of my worn pads, inspect the pads if they need to be replaced change them and add some fluid thats all.
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
mike730
Jan 12, 2018 04:25 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
derres
Aug 28, 2015 03:27 PM
Lsantana757
Jul 20, 2015 09:08 AM
