tires PSI for OEM 19's
Old Jan 12, 2007 | 05:02 AM
French87's Avatar
my low tire pressure indicator went off today and so i checked all my tires at a gas station, all were ~30/31 except one was 28 (which is what it goes off at) i put it up to around ~34 and the indicator didnt go off, is it because its too high?... i figured it would be on for a bit til the sensor readjusts itself and what not but after driving for a while, parking for a few hours at a buddy house, then going back home, its still on...
the manual said the indicator goes off at 28, but didnt see anything that said what it SHOULD be at, or whats too high, im sure its in there but i obviously missed it. anyone happen to know off hand?
Old Jan 12, 2007 | 09:52 AM
doomsday123's Avatar
I keep mine at 36 and the light goes off when they are all around there.
Old Jan 12, 2007 | 10:09 AM
Bigd2k6's Avatar
now that it's cold, i readjusted my pressure to 36 at the gas station about 2 miles from my house. door placard says 35 so it's pretty close. the sensor should reset after driving a few miles. if it stays on for a whole day and the pressures are all around 34, take it to the dealer because it could be a bad sensor. we had one go out on my wife's jeep that actually displays the number in each tire. went blank for a few miles on a road trip and then went back to normal reading. took it to the dealer and they said it was going bad.
Old Jan 12, 2007 | 11:49 AM
wilksoner's Avatar
36 psi
Old Jan 12, 2007 | 12:33 PM
jersey-G's Avatar
Look on the inside of the door.
Old Jan 12, 2007 | 01:26 PM
watsgoodG's Avatar
i had my tire pressure at 42 psi for a while...you think i did any damage?
Old Jan 12, 2007 | 01:31 PM
LjN_728's Avatar
^ Isn't max @ 40 psi?
Old Jan 12, 2007 | 01:55 PM
watsgoodG's Avatar
i think its higher than that
Old Jan 12, 2007 | 01:56 PM
LjN_728's Avatar
^ That's what it reads on my 19" Bridgestones
Old Jan 13, 2007 | 12:51 PM
Bigd2k6's Avatar
you probably just wore some of the meat in the center area. depends on how long you did it for.
Old Jan 13, 2007 | 12:56 PM
ISMSOLUTIONS's Avatar
For best handling and ride and tire wear -
Front at 36 and rear at 38
Rick
Old Jan 13, 2007 | 01:01 PM
strife's Avatar
35
Old Jan 14, 2007 | 03:32 AM
French87's Avatar
well theyr all above 30 and the manual says the low tire pressure light comes on when they are under 28.... i had one AT 28 and i put it up to around 35 and the light wont go off, ive driven about 20-25 miles since i filled that one up.
its been like this for over a day now, any suggestions?
Old Jan 14, 2007 | 09:36 AM
macr6's Avatar
Take it to the dealer. I had this happen to my 05 coupe. Took it to the dealer and they reset it. If you know the psi is the same after 24 hours then have them reset it or test to see if its going bad.
Old Jan 14, 2007 | 09:47 AM
V35 Skyline GT's Avatar
6MT Coupe
Mine go off around 28-29. Light went off after about 5min on the road after filling with air.
Take to Dealer, sounds like a sensor gone bad or system needs reset/recalibration.
