nitrogen filled tires, can i add regular air
Old Jan 26, 2007 | 03:18 PM
Rphillips6487's Avatar
yah, should be all rightt
Old Jan 26, 2007 | 04:02 PM
b00stedjustin's Avatar
Originally Posted by usual_suspect
There are several theoretical advantages to using nitrogen in tires:
- contains less moisture, so pressures stay more constant with heat cycles (that's why racers user it)
- completely inert gas, so less corrosion of wheels and oxidization of rubber (that's why truck fleets use it)
- less pressure loss since larger nitrogen molecules don't migrate through the rubber as easily as oxygen molecules (questionable, IMO)
You'll hear stuff like "lighter/heavier", "better handling" or "fire resistant" mentioned, but these are just stupid.
In actual practice, street cars don't heat tires up enough, or keep tires long enough to get any real benefit. On the other hand, it won't do any harm either.
+1. I've never used it and only know people that use it for cars that they are regular attendants at road courses. It's pretty sick how F1 technology has filtered down throughout the years.
Old Jan 26, 2007 | 06:04 PM
avs007's Avatar
Originally Posted by txgcoupe
But remember, water vapor will constitute less than 1% of the air in the tire.
I'd argue with that.... If you had your own compressor like me, with an inline dessicant filter, than yes.... But I've gone to many gas-stations, and the "Free-Air", pumped out so much water vapor, you could see the water droplets flying out of the hose... I sprayed my hand, and after a few seconds, there was water running down my arm....
Old Jan 26, 2007 | 06:45 PM
kyeguy82's Avatar
Correct me if I'm wrong, but I believe that Costco has the equipment to fill tires with Nitrogen.
derres
Aug 28, 2015 03:27 PM
multimut
Canada
Jul 26, 2015 08:43 PM
vstypicals
Jul 20, 2015 10:55 PM
realtalk21
Jul 20, 2015 09:07 AM
papo020
Jul 17, 2015 10:30 PM
