Rumbling noise from wheels???
Old Feb 6, 2007 | 09:00 PM
JAXG356MT's Avatar
i recently replaced my rear tires and now i hear a rumbling noise when the car is moving i hear it when i go slower ive put about 300 miles on these tires...i got an alignment done yesterday so i dont know what is causing this anybody have any suggestions?...thanks
Old Feb 11, 2007 | 12:31 PM
JAXG356MT's Avatar
anybody know what could cause this....
Old Feb 11, 2007 | 12:46 PM
IP G's Avatar
maybe tire balance?
Old Feb 11, 2007 | 01:19 PM
xx7sephiroth7xx's Avatar
G
were they put on correctly (i.e., put in the correct direction)?
Old Feb 11, 2007 | 01:30 PM
nchima's Avatar
align it.
Old Feb 11, 2007 | 02:18 PM
JAXG356MT's Avatar
i got it aligned and balanced and the tires were put on the right direction....anything else?
Old Feb 11, 2007 | 02:44 PM
Rphillips6487's Avatar
alignment and/or tire balance should be the only reason for wheels rumbling and if your had that done (correctly) than your tire(s) could we warped
Old Feb 11, 2007 | 04:57 PM
Mr.GEE's Avatar
20 Year Member
What about the front tires? I have bad rumbling from the front tire feathering problem that was common on early G Coupes and 350Z's. Once the tires have worn in a way to cause noise, balancing and alignments will not help at all with the noise.
Old Feb 11, 2007 | 05:06 PM
redwillow's Avatar
20 Year Member
what gee said...sounds like uneven wear on the front tires.
Old Feb 11, 2007 | 06:53 PM
icab's Avatar
+1 here. Are you sure it's coming from the rear tires? I was recently trying to find out what the noise was all about. Search the forum for "negative camber." If it's coming from the front tires, that's why.
I'm not sure if the rear tires have a negative camber as well.
Old Feb 12, 2007 | 01:06 AM
urban's Avatar
I have the same issue but it is the front, it is more pronounced when going slow or slowing down to a stop.
Old Feb 12, 2007 | 12:48 PM
YaddaYadda's Avatar
I have the cupping/feathering problem on my 04 with Yokohmaha AVS 100 for the fronts. The tire roar was loud as hell. I replaced with el-cheapo Kumho Ecsta SPT with alignment and now no more roar. I am sure the roar will come back once it cups again, but hoping that wont happen for awhile.
Old Feb 12, 2007 | 12:51 PM
Potty_Pants's Avatar
bearings ?
Old Feb 12, 2007 | 01:55 PM
new35's Avatar
directional rotation?
want to talk about tire roar... I have 4 blizzaks mounted all around for the winter months... loud when slow...smooths out at speed...
car drives thru anytype of Snow conditions..w/out problems
Old Feb 19, 2007 | 06:42 PM
JAXG356MT's Avatar
it is the front tires....they are worn a bit more on the inside due to the negative camber....so would rotating them by unmounting them and switching the fronts keeping the direction correct fix this problem...
