DO I NEED TO TORQUE CRAWFORD BOLTS
Re: DO I NEED TO TORQUE CRAWFORD BOLTS
All bolts should be torqued to their specification, specially in the plenum , you want equal pressure for a uniform fit to minimize leaks , for that size bolt and if you do not have the specific value from the repair manual , use the general chart, 8 to 10 foot pound of torque for that bolt size , unless some one knows the specific value and can enlighten us .
I would not go any tighter than that.
Quote from the shop manual...
4.9 - 6.9 N-m (0.5 - 0.7 kg-m, 44 - 61 in-lbs)
That works out to 3.67 - 5.08 ft-lbs
Be careful, I'd recommend not exceeding 5 ft-lbs. Twisted off cap screws are had to get out. The shop manual provides a percise order which essentually starts at the center, moving back and forth and working out towards each fender.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
DRG35R
Sep 16, 2015 05:33 AM
