Removing Fender plastic, help.
Old Mar 12, 2007 | 01:02 AM
jclit's Avatar
Is it ok if i remove the plastic lining thats inside the front fender? Im dropped on Z S techs and my tires (255/35/20) keep rubbing every time i hit a bump. Will i be ok? or should I just keep letting it rub till it creates a hole?
Old Mar 12, 2007 | 01:09 AM
light's Avatar
don't man.. read the service manual. to remove the fender liner.. there are three screws goes on the plastic things..
Old Mar 12, 2007 | 02:06 AM
redlude97's Avatar
where is it rubbing, its been done, and is done by alot of superlow cars. I think you'll be fine in cali since it doesn't rain much and salt isn't an issue. You can get undercoating spray, and coat everything except for the engine area with it if you are really worried. The fenders can also be rolled further to provide a little more clearance
Old Mar 12, 2007 | 02:17 AM
jclit's Avatar
Im only getting rubbing issues in the front, It looks to be the plastic inside. I thought the front fenders couldnt be rolled? Even if they were able to get rolled, i dont think it would solve my issue, as its the lining thats getting hit.
Old Mar 12, 2007 | 02:25 AM
redlude97's Avatar
I'm still saying remove the fender lining, its just once you do, the fenders can be further rolled. The fronts are only partially rolled and will give you a little more clearance in case thats where you are rubbing
Old Mar 12, 2007 | 01:48 PM
BW350GTskyline's Avatar
ur upper control arms dont rub on the tire..
Danielek
May 1, 2022 01:28 PM
Thebaws11
Nov 30, 2016 12:54 PM
TeamNoSleep
Sep 13, 2015 07:40 PM
G35CO
Sep 4, 2015 09:27 AM
