5w30 vs 10w30: Problem?
Old Mar 12, 2007 | 02:02 PM
BocaCoupe's Avatar
G's Up, Ho's Down
I just had an oil change and they put 10w30 instead of 5w30. I live in Florida so the temp is usually 75+. Is there any problem with them switching to a 10w30?
Old Mar 12, 2007 | 02:06 PM
Jeff92se's Avatar
Red Card Crew
Nope. No biggie as the Florida temps won't really affect the W rating aka winter weight viscosity.
Old Mar 12, 2007 | 02:11 PM
SilverII's Avatar
I dont think so....
I run 5w30 in the winter and 10w30 in the summer.
Old Mar 12, 2007 | 02:47 PM
Msedanman's Avatar
O.F. Administrator
In your climate, 10 might be a better choice anyway...
Up here in the Great White North is a different story tho.....
C.
Old Mar 12, 2007 | 04:12 PM
FenixL1P's Avatar
doesn't user manual specify 5w-30??
Old Mar 12, 2007 | 04:30 PM
gary c's Avatar
Oil viscosity.......?
It really doesn't matter if you use 5W30 or 10W30. If your using synthentic
don't switch back to normal oil......on the other hand it's better for your G
if you use synthentic but still change it every 3K miles!
Old Mar 12, 2007 | 04:33 PM
Jeff92se's Avatar
Red Card Crew
Originally Posted by gary c
It really doesn't matter if you use 5W30 or 10W30 If your using synthentic.
Correct
It doesn't matter. Switching doesn't do anything negative.
yeah probably
Incorrect.
Old Mar 12, 2007 | 06:22 PM
UMBG35's Avatar
Along with 10w-30 and 5w-40. I use 10w-30 in the summer. I generally put in 3qts 10w-30 with 2 qts of 10w-40 in the summer. This past change it was 4 of 5w30 with 1 of 5w50.
Old Mar 12, 2007 | 06:46 PM
redlude97's Avatar
Actually they specify 10w-30 or 10w-40
Old Mar 12, 2007 | 07:00 PM
ttrank's Avatar
Grocery getter
Who makes 5W50? Amsoil/Motul or is there some you can get local?
Old Mar 12, 2007 | 07:02 PM
Msedanman's Avatar
O.F. Administrator
Castrol Syntec....(I use it).
C.
Old Mar 12, 2007 | 07:56 PM
Chrlesmd's Avatar
Here some basic info about oil.
http://www.nordicgroup.us/oil.htm
Old Mar 12, 2007 | 08:32 PM
UMBG35's Avatar
Yeah, Castrol at walmart or at autozone, it's 4.49 on sale right now. I'm gonna run Castrol 0w30 (GC) for the next couple changes since it runs almost like a 40 weight. I hope all the praise from bobistheoilguy.com on GC is true. It's suggested to be the best match for our VQs by many members on board. However, one member got good results on pennzoil dino (better than penzoil platinum) based on blackstone results.
Old Mar 12, 2007 | 08:33 PM
UMBG35's Avatar
My mistake... it is 10w-40 not 5w.
Old Mar 12, 2007 | 08:36 PM
nghiars's Avatar
every 3k is overrated and overkill... unless u do a lot of short distance driving where your car hasnt completely warmed up... propaganda started but jiffy lube and oil change companies... check your owners manual and the oil manufacturer..
