Upgading spark plugs
Old Mar 14, 2007 | 03:04 PM
jonnylaw's Avatar
While the differences may not be much, I was looking to swap out stock spark plugs w/ NGK iridiums. Anyone know how many sparkplugs I will need (I assume 6 correct).
Any know of any disadvantage of swapping out stock (platimum sparks) for iridiums? I was looking at the nismo branded ones ordered from japanparts.com, but they are just the NGK iridiums, correct?
In case anyone hasn't notice the new g35 sedans now come with iridium spark plugs, along w/ the dual intakes and less restrictive exhaust.
Thx for the Input!
Old Mar 14, 2007 | 03:16 PM
Clemmdog's Avatar
V6 = 6 spark plugs. Yes you are correct.
Old Mar 14, 2007 | 03:19 PM
BadBoy06's Avatar
I'm not sure you will notice any difference. Maybe if you went
with a colder plug but why would you?
Old Mar 14, 2007 | 03:22 PM
jonnylaw's Avatar
yea, I realize I would not notice any substantial improvement, even with a slightly colder plug. But, I just figured w/ a couple of breathing mod's maybe a colder plug would help? I also found it interesting that the new g35 is using iridium spark plugs as opposed to the platinum ones that are on our current G's--Since Nissan is now using iridium sparkplugs for their new G's, why not swap them out for my year? But if the cost and time involved in doing so is not worth the result, then I may just drop it.
Old Mar 14, 2007 | 04:27 PM
G35 Mass's Avatar
6 NGK Iridiums cost me 54 dollars at my local NAPA this week.
Here's a DIY I'm working on....
https://g35driver.com/forums/engine-drivetrain-forced-induction-diy/144767-diy-spark-plug-change.html
Old Mar 14, 2007 | 04:43 PM
speedgeek's Avatar
Thumbs up
Awesome DIY! Very well put together.
Do you think it's worth indexing the plugs? I did this in my GSX.
http://www.fordmuscle.com/archives/2000/07/indexplugs/
Old Mar 14, 2007 | 04:50 PM
Jeff92se's Avatar
Red Card Crew
If you put one step colder plugs in a na motor, you WILL lose alot of performance. If you want to use Iridiums (waste of $ to me), fine. but use the correct heat range.
Old Mar 14, 2007 | 05:33 PM
BadBoy06's Avatar
Correct.
Here's an example on my other car. I did the switch as mentioned above
(platimum sparks) for iridiums)
No gains whats so ever (this is with scans from my LS1).
The next time I just used OEM's and saved my money for something else.
And yes, you should index the plugs.
Old Mar 14, 2007 | 05:34 PM
BadBoy06's Avatar
forgot to mention..this was on a S/C motor
Old Mar 14, 2007 | 06:26 PM
blksnake's Avatar
deleted
Old Mar 14, 2007 | 06:32 PM
Msedanman's Avatar
O.F. Administrator
+1. Don't change the heat range for relatively unmodded engines.
......and don't forget to use a little anti-seize on the threads when the new ones go in.
They go in potentially for years and can be very difficult and even ruin heads on removal.
C.
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
KallDay86
Jan 8, 2016 12:42 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
