clutch,brakes and timing belt
Old Mar 21, 2007 | 08:57 PM
SkyBlueG35's Avatar
does anybody know how much it costs to replace the clutch and flywheel,brake pads and rotors (stock brembo's) and timing belt on a 2003 G35 Coupe
Old Mar 21, 2007 | 09:06 PM
SkyBlueG35's Avatar
i also need new syncros and a throw out bearing
Old Mar 21, 2007 | 09:29 PM
Mr.GEE's Avatar
20 Year Member
There is no timing belt. The 3.5L engine has timing chain. As far as the rest of the items you mentioned, it all depends what you buy, where and who does the installation. If you go to the dealer, buy some industrial size Vaseline and lube up before they bend you over.
Old Mar 21, 2007 | 09:35 PM
SkyBlueG35's Avatar
does the timing chain need to be adjusted or replaced
Old Mar 21, 2007 | 10:03 PM
Mr.GEE's Avatar
20 Year Member
No, it does not. There is an oil pressure activated tensioner that constantly keeps pressure on the timing chain as long as the engine is running. It will usually outlast the life of the engine, unless if for some strange reason it breaks, but it is not likely that something like that would happen.
andrewvk
Interior
Aug 6, 2015 05:51 PM
TurboEE
Jul 31, 2015 10:41 AM
sahizzle110
Jul 29, 2015 11:36 AM
neight
Drivetrain
Jul 28, 2015 04:47 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
