Anyone know the Infinit Part # of the seat retrofit kit for around the drivers seat power controls that goes with the TSB for seat discomfort? I want to get that done on my coupe - but my dealer says they cannot find the correct part # and that the TSB only applies to sedans not coupes. But all the info I could find says it applies to both. They are telling me they are calling the engineers at Infiniti and still don't have a part #. Can anyone help me out here - or point me in the right direction. Thanks.
i think it only applies to sedan
04 6mtC, DG - possibly most babied G on the board.
Guest
From what I heard at the dealer, it only applies to the sedan. The FX has a big problem with seat shifting that they are still working on a fix for.
04' G35 Coupe(finally in the garage)
6-sp Diamond Graphite/Willow w/Premium
From the Infiniti site here is the TSB number and brief description:
ITB03018
IF YOU CONFIRM: The power seat switch is causing discomfort to the vehicle driver, ACTIONS: - Remove the plastic support plate from the power seat switch bracket. - Install urethane foam pad behind the power seat switch bracket. See this bulletin for further detail.
Let me know if you can get this done on your coupe. I have the same problem and am planning on having it down, but haven't gotten over to the dealer yet.
ITB03018
