Pic of painted engine cover.
Old Dec 29, 2003 | 10:31 AM
fluffydot's Avatar
Re: Pic of painted engine cover.
So what kind of paint did you use and what kind of tools will need? any sanding required?
Old Dec 29, 2003 | 12:20 PM
WRAH's Avatar
WRAH
Now you need the right side cover that matches our left one, i've seen a couple of times....
looking for the part
Old Dec 29, 2003 | 01:53 PM
tik1's Avatar
I would assume he used something like this <a href="http://www.duplicolor.com/products/engine.html">http://www.duplicolor.com/products/engine.html</a>.
This company was mentioned on <a href="http://www.hirevtuners.com/site/preshowseg.php?PreID=124&SegID=131">Hi-Rev Tuners</a>.
6MT Coupe / Diamond Graphite / Graphite
Aero / Premium / Splash Guards / Trunk Mat
3M Clear Bra
Old Dec 29, 2003 | 02:22 PM
Triji's Avatar
I used this paint, on the engine cover you dont have to use the high temp paint if you don't want to, the cover doesn't get overly hot for this paint to handle. Once I start to get more into it and paint on the engine itself I will use the high heat stuff. There is a better color selection with the "truck,Van, Suv " paint as well. Do not neglect to use both the primer and the clear coat if you are going to do this. Without the primer the paint won't stick and the clearcoat puts a nice sheen on everything.
2004 Coupe, 5AT, Twilight blue / Willow int, K&N Typhoon CAI, Hyper Grounding Kit, Mtek Xenon Fog/High, Clear corners, Hypers, 18's, Aero, tint, Premium.
Old Dec 29, 2003 | 06:47 PM
G35TR's Avatar
Looks great!! I will give this a try in my Laser red!!
Old Jan 1, 2004 | 01:40 AM
G35angsta's Avatar
Hey man, much props, looks really good!
So I'm looking at the pic of your intake it's a very clean setup, but im wondering where is the maf sensor, is it built in to the Typhoon system? I have the Nismo CAI and it uses the factory MAF within the piping of the upper part of the intake i dont undertsand why and how yours is so clean. Yours looks like one straight pipe down to the filter.
Old Jan 1, 2004 | 02:26 AM
Triji's Avatar
Hey thanks
The MAF sensor is right above the K&N sticker on right side of the tube above the Bypass valve. You can see it pop out right there, it is built in to the K&N CAI so you do not use your stock MAF port.
Old Jan 1, 2004 | 02:39 PM
6MT_Coupe's Avatar
I have to add my 2 cents just like everyone else.... Damn does that SHI_T look great! Really nice job.... When it is done right (clear coat and all), you totally can't go wrong and it just looks awesome. Love how it meshes with the K&N blue intake and the blue grounding kit.... Great job! Enjoy.
Here's to alcohol : The cause of ... and answer to all of life's problems.
- Homer Simpson
Old Jan 1, 2004 | 07:41 PM
willthethrill's Avatar
WOW!!! yes in capital leters so you know i mean it. I must do this as soon as the weather warms up. Did you need to sand down the areas at all before you primered???
Old Jan 1, 2004 | 10:09 PM
Triji's Avatar
Thanks guys...
No I did no sanding at all, I put 2 good coats of primer on, then 3 coats of paint, followed by 2 coats of clear coat. All in all took 2 days to complete, 2 hrs for taping and prep... then allow for thurough drying times in between coats. It was a fun DIY project to do...
jsimonk
Dec 22, 2023 03:49 PM
netcbc
Exterior - Body Parts CDN
Sep 10, 2015 09:20 AM
linedr89
Aug 17, 2015 05:11 PM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
