programming Homelink question/problem?
Old May 8, 2007 | 09:46 PM
oneha1980's Avatar
i just programmed the Homelink and it works. now, we have 2-car garage with 2 seperate garage openers but only one of them works(whatever i program the last). is something wrong with my Homelink or thats how its supposed to work? cuz Acura TL-s also does the same thing.
Old May 8, 2007 | 09:50 PM
srmfball's Avatar
I cant get my homelink to work
Old May 8, 2007 | 09:53 PM
GreenGoblin's Avatar
The goblin resurrection
I could never get mine to work either not sure read the damn directions like 10 times too
Old May 8, 2007 | 10:18 PM
whoakevin's Avatar
The memory on your garage opener (the motor) may be full. Happened to me twice. Check out your manual or look for one online if you didn't already. Find out how to reset it. One thing though, everything will be erased (homelink on other vehicles, keychain garage opener, etc) so you will have to set everything again. Good luck.
Old May 8, 2007 | 11:17 PM
GGG Ya's Avatar
mine works
but it could just be your actual garage door opener or maybe somehow the programming of the 2nd button didn't work, the only thing you can really do is try to program it again
Old May 9, 2007 | 04:14 PM
GT-Ron's Avatar
Homelink isn't compatible with all openers. In fact, I think you're most likely to encounter compatability issues with Wayne Dalton openers (not all). It sucks having Homelink and still having to carry/use another opener.
Old May 9, 2007 | 04:23 PM
iamdjpaul's Avatar
IC Paul
The homelink works on my garage, I just wish I could get it to open my gate to my apt complex.. Tried so many times with no luck. If anyone has fixed this out can yo PM me.
Thanks
Old May 10, 2007 | 02:54 AM
MeetJoeAsian's Avatar
the homelink mirror is not made by infiniti...it's a universal mirror that is used on acura, toyota, lexus, nissan...etc....they should all work the same...
Old May 11, 2007 | 05:52 PM
RacerX35's Avatar
Like it was stated earlier, when you set the code in the car, you have to reset the garage door opener too. When you reset the opener, you then have to go to the car and hold the programmed button until the opener learns the code from the car. I have mine for my garage door opener and my brother's gate to his house. Now I just need another thing to open for the third button.
Later,
Ray
TNRocker
Sep 21, 2015 08:36 AM
Detailed Image
Sep 18, 2015 03:43 PM
Detailed Image
Sep 17, 2015 07:38 AM
