Splashguard installation? Anyone done it?
Old May 24, 2007 | 09:51 PM
Jining's Avatar
Just curious if anyone has installed splashguards. Im about to order some and im curious what is involved. Thanks a lot.
Old May 24, 2007 | 09:52 PM
Jining's Avatar
also, is 160 for front and rear splashguards a decent price?
Old May 24, 2007 | 10:19 PM
Deezflip's Avatar
I've installed rear splashguards on mine, requires drilling on the plastic bumper fender part(right behind the tire).
It's fairly easy, comes with instructions. The area already has a circle marking of where it needs to be drilled. But i recommend cleaning the area since some part of the splashguard is double sided taped.
$160 is not bad at all, i paid close to 90 at the dealership for just the rear.
Old May 24, 2007 | 11:55 PM
partyman66's Avatar
I did mine. It was really easy. I'd recommend taking the tire off as you install the splash guard for each wheel, at least in the rear. If I remember correctly, I didn't have to take off the fronts because I just turned the steering wheel all the way in the opposite direction, so that it gave me more clearance to drill where I had to.
It's pretty much an idiotproof install because you use the splash guard as a template and just drill in the spotswhere the holes in the splash guards line up with the plastic on the undbody.
Old May 25, 2007 | 12:50 AM
G35kidd's Avatar
+1.. I took the rear tires off to install mine but not the front and just drilled where the holes were
Old May 25, 2007 | 01:12 AM
Jining's Avatar
coo coo thanks guys
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
