Dome light size
Old Jan 22, 2004 | 08:42 AM
zippiziggi77's Avatar
Dome light size
I am planning to change my dome lights to white, but I have no clue what size I should get. Does anyone know the dome light size for G35C??
Old Jan 22, 2004 | 10:20 AM
cupid's Avatar
Re: Dome light size
Polarg size will be M-16
Standard size reference is 3022
You should also change the courtesy light by the door; size is 194 wedge type (same as clear corners)
The dome light I don't use much since because they are too bright but courtesy door light is always ON when you open the door and changing them to super white looks really nice~
<font color=blue>2004 G35 Coupe | 6MT | Aero-kit 4-piece | Ivory Pearl/Graphite Lthr | 5% Tint | Grounding Kit | Xtreme White everywhere~ |</font color=blue>
Old Jan 22, 2004 | 11:51 AM
SFLG35's Avatar
FGC President
Re: Dome light size
i ordered the piaa t-6 extreme white light bulbs for the map and door lights. the piaa lights are 10 watts and the owners manual says that the ones in the map light are 8 watts which shouldnt be that big of a deal only 2 more watts. the ones in the door though are 5 watts. this is from my other post. the door lights are not 194 wedge bulbs but are the same as the dome/map light. i have been runnin them now for a while with no problem. i would definately suggest changing out the doors to be the same as the map lights it will look better. overall i am very happy with the setup, it is much brighter and looks a looks better.
Map and Door light Wattages
Daniel
5AT Coupe / DP / Willow / Aero / Premium / 3M Clear Bra / 5% Tint All Round / Ground Kit / Clear Corners / Piaas Everywhere / Shock Sensor
Old Jan 22, 2004 | 02:14 PM
Aldo420's Avatar
Re: Dome light size
cupid no its not homie.. IF its the door light im thinkign about(which i changed) it would be a t-6 bulb.. which is not the same as the clear corners.
Old Jan 22, 2004 | 02:48 PM
hoshtaylor's Avatar
Re: Dome light size
Anyone got any pics of white bulbs in the interior...???
"Operator, give me the number for 911!"
- Homer Simpson
Old Jan 22, 2004 | 07:52 PM
Shader7's Avatar
Re: Dome light size
Hmmm . . . I always thought the dome (map) lights were pretty white already. Anyone try to change them out? Are they easy to replace?
Black/Willow 03.5 6MT, Premium, Navi, Aero, SAT
350Z Nismo CAI
Old Jan 22, 2004 | 09:47 PM
willthethrill's Avatar
Re: Dome light size
here is mine
PIAA extreme white
Old Jan 22, 2004 | 11:51 PM
Shader7's Avatar
Re: Dome light size
Will, do you take the lense out to replace the bulb? If so is there a trick to it? I didn't find an easy way to pop mine out.
350Z Nismo CAI
Old Jan 23, 2004 | 08:17 AM
Re: Dome light size
Yes,
Take a butter knife wrap a tissue or another thin cloth around it and place it in the side in center and pry towards the window, if that makes any sense. I found putting them back on was a little more difficult than getting them off. I believe there is a picture in the manual that shows how to do it, or there may be one on here. Im sure it will be faster just to get the manual out though.
Old Jan 23, 2004 | 09:01 AM
SFLG35's Avatar
FGC President
Re: Dome light size
good choice on bulbs will. same ones i got. they are much brighter. one of my friends called them hospital lights since they are so bright, but i like them. can really see things now.
Daniel
Old Mar 1, 2004 | 09:39 PM
fluffydot's Avatar
Re: Dome light size
Just thought I'd make my contribution to the lighting resources...
I definitely had some trouble putting the light cover back on. seemed like one side just would get into the right place and even though I got it on a couple of times it would let you press down on it anymore.
anyway here is a pic.... Dome Light on the left (31mmx10mm)
and a Wedge 168 bulb (side marker + trunk) on the right for comparison.
Old Mar 1, 2004 | 09:42 PM
fluffydot's Avatar
Re: Dome light size
can anyone confirm if the courtesy/step lights are the same size and type?
I tried my best but just couldn't get the darn cover off...
well it didn't help that it dark out and ground is wet from rainning all day...
I am thinking of ordering from www.superbrightleds.com
anyone have experience with them?
Old Mar 2, 2004 | 09:00 AM
SFLG35's Avatar
FGC President
Re: Dome light size
they are the same as the ones you have on the left side of the ruler. cant think of the right name right now but for some reason t6 comes to my head
Daniel
5AT Coupe / DP / Premium / Aero / Clear Bra / 5% Tint - 30% Windshield / Ground Kit / Clear Corners / Shock Sensor / L.E.D. Hood Lights / Z - Tube
Old Mar 2, 2004 | 01:23 PM
ncozby's Avatar
Re: Dome light size
They are indeed T6 bulb.s
<font color=blue>04 DG/G Coupe - St. Louis, MO
Premium, Aero, Performance, Splash Guards
Tint - Grounding Kit - UItinon 6000k - Rebadged
Clear Corners - Tein S-Tech- K&N Drop-In</font color=blue>
