Gas gage question?
Old Aug 22, 2007 | 12:49 PM
Dubfound's Avatar
Gas gage question?
Any time I fill my coupe my gas gage never shows filled to the top. The pump will shut off but my gas gage will only say its ¾ to 7/8 full? I remember once upon a time it showed a full tank with the needle pointing above the full line. Anyone else like this? Is this normal?
Thanks, Shaun
Old Aug 22, 2007 | 02:14 PM
BW350GTskyline's Avatar
yea thats normal.. because our tanks our tapered so the fuel is able to run out the tank thoroughly... also there is a sensor in the tank that will tell the pump to stop pumpin and if im not mistaken iv read that the need actually gets ****ed up and tells the system that ur not full when in actuallity you are...
Old Aug 22, 2007 | 02:19 PM
Beebo's Avatar
we have 20 gallon tanks when i fill up it only gets 17 so i guess its normal
Old Aug 22, 2007 | 08:55 PM
Memphoman's Avatar
Today I had my coupe in for the exact same problem, they replaced my fuel tank sender unit. Just as I got to the dealership, my TPMS light came on, they say ALL my tires were reading 30PSI, which they upped to 35PSI. As a side note, they off loaded 14 new coupes as I was picking up my car, ALL of them are sold, with another 15 or so due in tomorrow, and ALL sold as well. Saw one with the "chrome" spoiler lip, IMHO, cheezy looking...
Old Aug 22, 2007 | 11:05 PM
jjyellow's Avatar
I had that problem after I got the recall done. Tank wouldnt read full so they fixed that, and after they fixed that, it wouldnt read below 1/4 a tank. Got that fix then it wouldn't read past 3/4 again. Did that about six times eventually they changed out the whole gas tank and it solved all my problems
Old Aug 23, 2007 | 10:04 AM
sonicjai's Avatar
didnt seem to notice this problem yet.. but then again, i don't like filling up as it hurts my eyes and wallet seeing it cost me 50 bucks to refill the whole tank so i only go half way each time =) lol
Old Aug 23, 2007 | 04:26 PM
Dubfound's Avatar
Was it a recall? Or did you have to flip the bill? If so what was the $$$ amount? ANy info would help man. I need this issue fixed! Its driving me nuts. My tank was at E today so I filled it and it only took 12 gallons? WTF
Old Aug 23, 2007 | 06:53 PM
crashnburn's Avatar
sounds like me, i thought i was going to run out of gas b4 i found a station, i was below e bad, got to fill up and only took 15.8 gals.... atleast i know i can go to bofu and back with gas light on
Old Aug 24, 2007 | 12:57 AM
jjyellow's Avatar
It was a recall for me in the beginning, but something happened along the way when they tried to do the recall causing all the problems I had
Old Aug 24, 2007 | 10:17 PM
Blue Lion's Avatar
Check out the InfinitiHelp website. There is a bulletin about this.
Old Aug 25, 2007 | 12:49 PM
Dubfound's Avatar
thanks bro! haha it happen today when I was wicked hung over. RAN OUT OF GAS! sucked.
Old Oct 2, 2007 | 07:03 PM
Dubfound's Avatar
Just got my car back for the first time in the shop for this issue. Looks like it will go in for a second time because they did too fix my fuel sending unit and it is still broken. I filled it yp and it reads 1/8th full. PITA
Old Oct 2, 2007 | 07:16 PM
jjyellow's Avatar
^^Hope they get it right the second time around b/c it can become a PITA
Old Oct 2, 2007 | 07:33 PM
Beebo's Avatar
damn so this is another thing to get fixed!
should i even bother if its only like 5 gallons?
Old Oct 2, 2007 | 07:43 PM
sliq's Avatar
this happened to me once. then hasnt happened again. ...yet. 07 G35 6spd
