How much does it cost to maintain a G?
Old Feb 5, 2004 | 11:00 AM
GThirtyFive's Avatar
How much does it cost for the routine maintenance of a coupe? For example an oil change and things like that?
Old Feb 5, 2004 | 11:14 AM
MyGUnit's Avatar
Re: How much does it cost to maintain a G?
same as any other car really..and if u get the automatic coupe..the brakes are covered for 30,000 miles, which is beneficial...
Personally, I put synthetic oil for my first oil change, so I can go for longer than the typical 3,000 miles regular oil gets.
2004 G35C AT
Black/Black Premium, Aero, Performance, Nav
Nav/TV Tuner
2-10" Pioneer Premiers
Rockford 801s amp
Old Feb 5, 2004 | 11:32 AM
blksnake's Avatar
...If you have to ask...
j/k ;-)
I haven't had any service on my car yet, but I would assume just as much as any other premium sports coupe.
Blksnake
Old Feb 5, 2004 | 12:59 PM
Actually, you are right, if I have to ask......
Old Feb 5, 2004 | 02:01 PM
Moss's Avatar
Ok..I've seen enough of these questions do make me finally go and pull out the price list that my dealer gave me for routine services. Hope this helps. This is from Bradshaw Infiniti in Greenville, SC
3,750 Mile Svc $39.95
7,500 " " 129.95
15,000 209.95
30,000 339.95
45,000 209.95
60,000 459.95
75,000 209.95
Under 15,000, they just change the oil and filter and check everything that can be checked. The 15,000K check is also oil & filter + replacement of some other things...too numerous to type. I was told by Bradshaw that any Nissan dealer can do the routine stuff as well.
Doug
2004 6MT, Desert Platinum, Side Molding, Splash Guards, Sat. Radio
Asheville,NC
Old Feb 5, 2004 | 02:07 PM
redwillow's Avatar
20 Year Member
<hr></blockquote>
i think the only other thing replaced is the in cabin air filter.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
Old Feb 5, 2004 | 02:39 PM
Moss's Avatar
For the "Premium Maintenance", they do the following:
Replace engine oil & filter
Lubricate all locks/hinges
Replace engine air filter
Replace in-cabin microfilter
Replace wiper blades
Rotate tires (except G35 coupe)
The "Schedule 1 Maintenance" is just as you said, oil/filter and in-cabin microfilter and inspect a bunch of stuff. There is also a "Schedule 2 Maintenance" which replaces the same things and inspects slightly less stuff. I guess you can stipulate which one you want depending on the size of your pocketbook and perceived need.
Doug
Asheville,NC
Old Feb 5, 2004 | 03:49 PM
Baumer's Avatar
you also need to consider comsumables such as tires and brakes. Tires are going to last about 20K miles and cost about $1300-$1400 (if you're getting Pilots). Brembo brakes last about 30K miles and cost about $200-$300 for new pads and turning the rotors.
6MT Coupe Prem, Aero, Nav.
Nismo Ti Shift **** // 350Z Pedals // 35% Tint
NAV-TV & PS2 // JL 12W6v2, JL 500/1
Grounding Kit // Injen CAI // Borla Exhaust
Eibach Springs // Volk SF Challenges
seagrasser
May 3, 2022 09:43 AM
MrIP35
Oct 25, 2015 11:13 PM
wow600rr
Sep 28, 2015 11:50 AM
Detailed Image
Sep 28, 2015 07:04 AM
