03 to 06 spoiler swap...HELP!
Old Nov 9, 2007 | 05:46 PM
ufgeee's Avatar
i have to imagine someone has done this as a DIY, because it doesnt look hard, however as i got started i noticed there are some small circular white snap clips holding the spoiler on. how do i get these off to get the wing off. im only able to get ahold of one, while the others i can barely see through a small hole.
any help or advice would be greatly appreciated
thanks, mike
Old Nov 9, 2007 | 06:24 PM
SteveBlake's Avatar
i don't really have any experience with this but just try to find something on the search, you might find somethin eventually. other than i can't help you out
Old Nov 9, 2007 | 07:13 PM
ufgeee's Avatar
searching was the first thing i did and came up with nothing unfortunately. there has to be someone out there that has had this experience and/or knows the remedy
Old Nov 12, 2007 | 11:25 PM
ufgeee's Avatar
still seeking help...anyone?
Old Nov 12, 2007 | 11:55 PM
Polishthrust's Avatar
The spoiler is bolted on, if u take off the trunk lining u can see all the screws. Im not sure if all the bolts are in same spot for both years...u might wanna think about a trunk swap.
Old Nov 13, 2007 | 09:23 AM
Beebo's Avatar
Originally Posted by Polishthrust
The spoiler is bolted on, if u take off the trunk lining u can see all the screws. Im not sure if all the bolts are in same spot for both years... u might wanna think about a trunk swap.
the bolts are not the same...
Old Nov 13, 2007 | 12:33 PM
akiatik's Avatar
i was also wondering the same thing, anyone?
Old Nov 13, 2007 | 12:58 PM
patman530's Avatar
bolts are easy, it is the 3M tape that is hard to get off
Old Nov 13, 2007 | 01:08 PM
xpl0sive's Avatar
use a heat gun for the tape... i'll come off easy. if you dont have a heat gun, a hairdrier will do just fine
Old Nov 13, 2007 | 05:31 PM
ufgeee's Avatar
the bolts dont line up...it appears the bolts are in the wing rather than the trunk itself. also its not just the 3m tape holding it on, there are a bunch of round plastic snaps holding it on and some of which i can not reach and even see. solutions????
Old Nov 13, 2007 | 05:33 PM
MixturePinoy's Avatar
Dude.. the only way to cleanly swap spoilers is to do a complete trunk swap. the bolts for the spoilers do not match up. so you'd have to drill the proper holes for just a spoiler swap. sorry i didnt see this earlier
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
MrIP35
Oct 25, 2015 11:13 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dseet
Oct 11, 2015 12:40 AM
JKL1031
Sep 11, 2015 07:58 PM
