pulleys help
Old Dec 7, 2007 | 06:59 AM
kuwait_G35's Avatar
pulleys help
hi there , i wana ask you somthin
i moded my G with the crank pulley... and it was great
now i order the other pulleys to upgrade to an Ultra SS kit
so ...
will i gain more HP ???
or nothin will be change ????
Old Dec 7, 2007 | 11:52 AM
05GCOUPE6MT's Avatar
You will free up a little more HP with the set.
Old Dec 7, 2007 | 10:33 PM
kuwait_G35's Avatar
mmmm
thnx 4 helping
Old Dec 7, 2007 | 10:52 PM
Triji's Avatar
Are you talking about the drive belt pullies? If so you are freeing up a bit of weight and they will spin easier in the lower RPM's... I am not sure how much HP you would gain but I do believe you would you would feel a quicker acceleration.
Old Dec 8, 2007 | 07:01 AM
kuwait_G35's Avatar
aha, thnx bro
Old Dec 8, 2007 | 11:29 AM
brianyun's Avatar
kind of off topic but did you do the install yourself?
Old Dec 8, 2007 | 11:35 AM
citymunky's Avatar
I have the whole set, and you will feel quicker acceleration. The power steering, and alt. pulleys are the same size as stock, they just weight alot less.
Old Dec 8, 2007 | 10:00 PM
kuwait_G35's Avatar
AHAA, i see
thnx
Old Dec 9, 2007 | 09:11 AM
Jason@Riverside's Avatar
The Power Sterring / Alternator Pulley's will not offer any performance gain.. >THey just look different...
They weight literally less than 0.2 ounce different off the top of my head... Virtually no weight savings and same side... not worth the labor IMHO..
Old Dec 9, 2007 | 12:53 PM
citymunky's Avatar
I installed my pulleys myself, and it's more than .2 ounce different . As for the labor the power steering takes less than 2 min's to replace , The alternator on the other hand did not want to play.(After like 3 hours, I have to completely remove the alternator, use PB Blaster/ 4' pipe wrench/ and impact gun, and it still give me a hard time )
Old Dec 9, 2007 | 02:16 PM
I am referring to the Alternator and Power Steering pulley weight. The crank is very different in weight.
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NailBomb
Oct 28, 2015 07:53 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
