Will there be rubbing? That is the question!
Old Dec 8, 2007 | 09:04 PM
Leonwho's Avatar
Following set-up ... Will it rub and involve fender rolling
Front Wheels: 20x9.5+24 R Disk
Rear Wheels: 20x11+29 O Disk
Tires Front: 245/35/20
Tires Rear: 285/30/20
Perfect fitment?
Opinions? Suggestions?
Wheels are Varianza T1S for those curious!
Thanks!
Old Dec 8, 2007 | 09:06 PM
06g35meister's Avatar
any drop, if not, no rubbing. i have 10mm less on each side, and its not even close. S-techs, DEfinately, H-techs, maybe????
Old Dec 8, 2007 | 09:11 PM
Leonwho's Avatar
The drop is being considered -
I have S-Techs ...
No camber kit, considering buying it and throwing it on along with the S-Tech Kit when I get the wheels.
No rub when dropped?
Old Dec 8, 2007 | 09:14 PM
i might go with a bit larger offset to play it safe, on S-techs i think any big bumps and youll be rubbin
roll and youll be fine
Old Dec 8, 2007 | 11:32 PM
Cost a G's Avatar
I think you'll be fine with just a roll. I have some t1s on order as well 20x9.5 +10 Adisk and 20x10.5 +0 Odisk
Gthizzle's thread on his t1s https://g35driver.com/forums/showthr...=187167...very smiliar setup to yours.
hope it helps..
Old Dec 8, 2007 | 11:54 PM
Leonwho's Avatar
hope it helps..
Hey there!
Roll if I drop it?
Or does one get a fender roll to begin with even with stock height set-up*?
What color coupe do you have, and what finish did you go with out of curiosity.
Why'd you go with an A-disk, just out of preference?
With the R-Disk I am able to clear a BBK kit when I get it -
And I get a bit over a 2 inch lip, and O-Disk gives you almost a 5 inch lip in the rear O_O
To be honest off-sets are behind over my head -
I went with a suggest off-set from Rick at Ravspec, hopefully all will go well.
Oh, also I hope I don't have to roll any fenders.
Old Dec 9, 2007 | 12:23 AM
Cost a G's Avatar
Roll if you're dropping it. You may not need any fender work if its at stock height. I have an IP coupe and I've gone with A disk in front to clear front stock brakes but with max lip ~4inch and O disk for max lip in the rear ~5inch machine finish as well. I wanted to go wider in the rear but 10.5 is as wide as it goes for STEP lip.
INVADER_6MT
Sep 1, 2015 10:19 PM
propho
Audio/Video/Electronics
Aug 27, 2015 04:56 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
