Two quick questions
Old Mar 21, 2008 | 12:31 PM
gcode's Avatar
Two quick questions
I just had a clutch replaced at 40k with OEM. (not my fault,nobody ever drives this car again but me) I have had mt before but never had to replace the clutch. I hear that there is a break in period and I wanted to ask if this is the normal. Also my clutch pedal is really soft with very little tension. The mechanic told me this was normal and will correct it self with time.
Also he didn't resurface the flywheel which I personally saw. I didn't look in bad shape but I'm also not a mechanic. I'm thinking in a few months I should just replace it.
Old Mar 21, 2008 | 07:03 PM
citymunky's Avatar
Yes there is a break in period of I think it's like 500-600 miles. During this period threat your clutch like would a newborn bady. As far as the pedal being soft, I not sure.
Also you can't resurface the OEM clutch because it is a dual surface clutch.
Old Mar 21, 2008 | 07:14 PM
gary c's Avatar
One quick answer....!
As long as the surface of your "flywheel" wasn't chewed up it should be
alright. No two clutches feel the same, you can have two identical cars
and the clutches will have a slightly different feel....it's crazy but that's
just the way it is....stop thinking about the feel and enjoy your G....
Old Mar 22, 2008 | 02:37 PM
scottsg35's Avatar
you can still resurface the clutch, you just have to do the center, then step it down on the outside. Ive even done it on a lightweight flywheel with a replaceable wear surface.
408G35Sedan
Feb 23, 2022 06:46 PM
skippyG
Jan 25, 2016 01:18 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
