Back Seat Won't Engage Latch
Old Apr 16, 2008 | 11:53 AM
Capitol G35's Avatar
I just installed a 300/4 on the backside of my backeat in my Coupe and when I try to reengage the back seat into the locked position it doesn't stay. The indicator button on top just moves down when I push the seat back.
I tried to move around the working parts for the latch cable assembly but nothing seems to work. I had a much larger amp installed before and had no problems. Is this common with JL amps? Help!
Old Apr 16, 2008 | 02:54 PM
Curt G's Avatar
Are you saying you think it's the brand of amp that keeps your back seat from engaging the lock? I think you need to get in the trunk with a flashlight and see if anything is touching the amp when the seat back is closed.
Old Apr 16, 2008 | 05:50 PM
I know that's what it sounds like but it didn't give me any issues with my BMF Soundstream amp. I finally took the JL amp out and it closed just fine. I think when the amp was screwed down it pressed on the release cable which kept the latch open. I was thinking about putting in spacers maybe. My drill crapped out so my batt is charging.
Old Apr 16, 2008 | 05:52 PM
BlueDevilBAMF's Avatar
Interesting... perhaps it does have something to do with the cable. GL let us know if the spacers work.
Old Apr 16, 2008 | 09:05 PM
Curt G's Avatar
Now that makes sense to me. Sounds like you have it under control (once you get a recharge). I just picked up a 500/1 so I'll have to watch out for this also.
Old Apr 16, 2008 | 10:50 PM
I moved the amp up an inch or so. It fixed the issue.
chinee
Jun 10, 2024 07:48 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
apintojr
Jul 23, 2015 10:52 AM
brian_z
Jul 20, 2015 01:30 AM
